Question about Whirlpool Refrigerators
We had power trip out last night, the keypad on my fridge freezer is locked and I don't know how to unlock it
Tempreture is stuck on low food is defrosting keypad is locked
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 04, 2012
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Gets stuck in defrost cycle, new thermostat already fitted
If you would like to stop the defrost timer from intermittently causing this, the defrost timer will need to be replaced. It's a simple part to replace and not expensive. Thanks, Sea Breeeze
Posted on Apr 27, 2009
  • 1891 Answers
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Posted on Feb 04, 2010
AndreaBl
  • 218 Answers
SOURCE: The refrrigerator and freezer not holding
hi there,
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
The temperature controls can display both the SET temperature
as well as the actual temperature in the refrigerator and freezer.
The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
Posted on Jun 15, 2010
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
Hello! I have an old model Kenmore 21 CF. The fresh food part of the refrigerator (the freezer seems fine) is not cold enough. Last night at 11:30pm I turned it from setting 5 to 7 (9 being the coldest)....
Check to see if the fan in the freezer is running, without it you get no cooling in refrigerator. If that's ok check for ice buildup on back freezer wall if so you have a defrost problem
Jun 22, 2011 | Kenmore Top Freezer Refrigerator
I have two problems. My fridge since yesterday keeps running for about 2-3 hours non stop. What should the control be set on in the tope freezer and what temperature should be be set on frigde part. I...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 12, 2011 | Frigidaire FRT21H8 Top Freezer...
Fridge was left open last night all night long and now it will not work..please help it is not even 1 yr old.......
the air ducts are froze up,if you lost your food you can just unplug it and leave the doors open and let it melt out,or you can unplug it,remove everything out of the freezer,remove the back inside wall of the freezer and melt out all the ice that you see,then look at the right side in the back down at the bottom of the freezer there's an air duct there,melt that out and in the fridge section look to see if you can see any air ducts on the left hand side wall,blow hot air into any of the air ducts that you see,just watch out,don't keep the heat blowing on the ducts for to long,you can damage the inside of the ducts,there's styrofoam in them and the heat can damage it,good luck it might be best to just let it melt out on it's own
May 11, 2011 | Frigidaire FSC23F7D Side by Side...
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
I have an Estate refrigerator by whirlpool Corporation, model # TT18DKXRQ01 with a 12-07 mfg. date. When you open the refrigerator door, as it closes, the freezer door always opens and closes. Apparently...
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Product information:
http://www.safety1st.com/usa/eng/Products/Home-Safety/Latches-Locks/Details/482-HS038-Lock-Release-Fridge-Latch
Oct 13, 2010 | Estate Refrigerators
Fridge freezer
it seem to me that the gas lewel are low in the system
Jun 16, 2009 | Refrigerators
There is power as the fridge is ok but the freezer is not frosting
Esto es un ejemplo de texto, con un video de prueba
Esto es una prueba
Jun 04, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
312 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
