Question about GE DBSR453EBWW Electric Dryer
Which way does thw tub turn
We just hoked up the cord to a new kenmore 400 dryer and can you tell me which way the tub should go counter clock or clockwise
  • 126 Answers
Counter clockwise should be the correct way..
Posted on Jan 07, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
How do I change my dryers cordes????
after you have disconnected your dryer from the power source, you see where your old cord connects in the photo!
take note which wire goes where, maybe mark one of the end ones with a marker, as the new ones will need to go on in the same way.
using either a Phillips screw driver or a small wrench or socket that fits the screws that attach the wires to the block in the photo.
turn counter clock wise to loosen ( they will be tight), remove screws & old wires.
reattach new wires in the same arrangement that the old wires were in. electrical connections need to be tightened fairly tight, you don't want them to come loose as arcing could result in an electrical fire.
Feb 05, 2015 | Dryers
I moved my Kenmore 400 series washer into our new house and now it makes a loud banging noise, and vibrates real bad on the spin cycle. It shakes the dryer beside it it's so bad. If I sit on the washer it...
THERE S A THIN NOT REAL LARGE CONCRETE BLOCK INSTALLED AT THE FACTORY UNDER THE MACHINE. A STRAP MAY HAVE LOOSENED OR BROKE, AND THE BLOCK MAY BE MISSING. ANY SMALL YET HEAVY WEIGHT WILL WORK.
IT APPEARS YOUR BOOTY MAY BE ACTING AS THE COUNTER WEIGHT!...IF NOT,,CHECK THE CONDITION OF THE TRANSMISSION COUNTER WEIGHT (AT BASE OF TUB UNDERNEATH)
Nov 04, 2013 | Washing Machines
Have a kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what? Can we wire our 3 prong plug from the other dryer to the four wire dryer? And how would we wire this way...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Kenmore 400 6942 Dryer
What type of screw is needed to attach the electrical cord on the back of a dryer
if it is old dryer best use a new terminal block(comes with screws)
Aug 13, 2009 | Kenmore 400 6942 Dryer
Washer leaks from rear. The hoses are perfect.
Hi .If you look, the tub is leaning towards the front . Theres a counter balance spring that has fallen off. remove the cabinet, to gain access, and replace the spring
Dec 23, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
GE DBSR453EBWW Electric Dryer Logo
67 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
