Replacement manual for sony mdr rf815r wireless headphones
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
mastersaintx
  • 928 Answers
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Posted on Apr 03, 2009
M2Tech1
  • 313 Answers
SOURCE: My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Posted on Aug 06, 2009
SOURCE: Sony wireless headphones, no sound with TV
no sound from tv
Posted on Feb 14, 2010
Sony wireless headphones keep shutting off
Check up the batteries and replace by new one.
Or remove the battery and reinsert.
Sep 09, 2014 | Sony MDR-7506 Professional Headphones
Sony MDR-RF4000K wireless headphones
Probably a bit late for the original poster, but just in case anyone else comes across this....
I also have the Sony MDR-RF4000K wireless headphones and the problem with the sound cutting out has got steadily worse over time, to the point where I felt like throwing them away. I replaced the batteries (use normal rechargeable AAs with a bit of card to trip the little switch that would normally be tripped by the Sony battery pack), however that had no effect on the problem.
After a little research I have established that the power on the headphones themselves is triggered by a pull switch in the right ear cup. When you put the headphones on, the padded headband is stretched and pulls the switch up, turning the headphones on. The headphones have always been a little big on me, and I can imagine that the headband has stretched permanently in the last few years, probably leading to the switch on being more marginal.
At any rate, although I don't have a fix, I now know that if the sound cuts out, I don't need to take the headphones off - just pull the headband up slightly on the right-hand side, or push the headphones as a whole down a bit, again on the right-hand side.
Jan 15, 2013 | Sony MDR RF4000K Wireless Headphones
Need replacement button battery for (Sony) MDR-IF320RK
I have the same problem.
I am about to wire in an AAA NiMH cell. Putting it on top of the plastic cap.
Aug 21, 2012 | Audio Players & Recorders
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
Are the MDR-RF925R useable with TV's
You can use MDR-RF925R with any thing that has Line Out RCA jacks and your tv should have TV Audio Out RCA jacks to connect this wireless headphone.
Thanks.
Jan 04, 2011 | Sony MDR-RF970RK Headphones
The jack on my Sony MDR-NC6 has broken off. Can I
See my tip on dodgy cable/jack on headphones. If the jack is different to the one shown, you should be able to get it from Maplin (UK user) or Radio Shack (USA).
May 31, 2010 | Sony MDR-NC6 Consumer Headphones
Nov 26, 2008 | Sony MDR-V500 Professional Headphones
104 people viewed this question
 Grubhead
Grubhead
