Question about Hitachi Gst Hitachi WH12DAF2 - 12V Impact Driver W/ Led Job Light 2 Bat 1.4Ah
EB1214S battery won't charge
Battery's won't hold strong charge
On your there are pins make sure they are making tight contact it could be that your charger is not charging the batteries to it's full extent
Posted on Nov 04, 2012
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
My 97 Pathfinder won't turnover. It clicks, it gives one push but then does nothing. It starts when I jump it and after it's charged for a while, but when it's been sitting it's like t
could be poor connection from battery to battery cable terminal. take off both pos. & neg. battery terminals, clean & reinstall, making sure there is a tight connection. if the cables are loose (even just one) or if the battery cable seems degraded with corrosion, they should be replaced. could also do a load-test on the battery... it should stay strong under load, and shouldn't drop to below 11 volts under load. if it does you have a bad battery, even though it may seem good otherwise.
Aug 10, 2012 | 1997 Nissan Pathfinder
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
2004 ford expedition charging system failed?
Sounds like battery not holding charge. Or a light staying on, boot or glovebox? Most likely battery tho.
Nov 16, 2011 | 2004 Ford Expedition
My chrysler 300 3.5 will not start
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you have the battery charged. The battery may be weak that's why it won't supply power to the starter.
If problem still persists then it's got to be the starter itself. If the starter is faulty, it won't turn the flywheel even you have a strong battery. If that's the case then the starter should be replaced.
Hope this helps and thank you for using FixYa! Have a good one!
Jul 17, 2011 | 2007 Chrysler 300c AWD Sedan New Cars
Stays on battery light on 89 buick
Hello and welcome to FixYa! If the battery light is on, I strongly suggest that you havethe battery charged. It can be an indication of a weak battery or a faultyalternator. If the battery light still on after charging then the problem willsurely be on the alternator itself. If that's the case the alternator should bereplaced to resolve the problem. If the battery won't hold charge even on a new alternatorthen the problem will be on the battery itself. It surely is in the end of it'sservice life and replacement will be necessary. You may try to reset it to by removing the positive batteryconnector, letting it sit for at least 5mins. then reconnect it again. Thiswill reset the system and can get the battery light off. Hope this helps and thank you for using FixYa! Have a goodone!
Jul 07, 2011 | 1989 Buick Century
Check engine light on, battery loses charge
If the battery light is on, I strongly suggest that you have the battery charged. It can be an indication of a weak battery or a faulty alternator. If the battery light still on after charging then the problem will surely be on the alternator itself. If that's the case the alternator should be replaced to resolve the problem.
If the battery won't hold charge even on a new alternator then the problem will be on the battery itself. It surely is in the end of it's service life and replacement will be necessary.
You may try to reset it to by removing the positive battery connector, letting it sit for at least 5mins. then reconnect it again. This will reset the system and can get the battery light off.
Dec 18, 2010 | 1996 Ford Explorer
Battery not charging info light on
Nov 27, 2010 | 1998 Cadillac Eldorado
Hitachi Gst Hitachi WH12DAF2 - 12V Impact Driver W/ Led Job Light 2 Bat 1.4Ah Logo
308 people viewed this question
Top Hitachi Gst Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Hitachi Gst Tool and Hardware - Other Expert? Answer questions, earn points and help others
