AIWA Digital Audio System Model-NSX-WV89. No Power
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
jerryg50
  • 1667 Answers
SOURCE: aiwa nsx-aj50
The power supply, and or the output stage can fail in these units. This may be on the expensive side to service.
Jerry G.
Posted on May 14, 2008
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Posted on Apr 30, 2011
  • 7 Answers
SOURCE: AIWA shelf system volume button
hi there if u want fix volume botton,u need open total aiwa set,but very hard job need a bit pasion,it was happned to me too!>Wht u gona doo u need open central part where screen connected there aiwa wolume boton system,u need open that all,befreo u need take it out botton control plastic front set,but be gentely because if bottons fall down u can put them back then same pose,So u need the volume panel open,u will see small controler siting on the micro chip i can take it that out from panel of volume,then clean it tootbarash,Possible can be dirty or oily.i did also that same clean and put everything same back,it cost me 5 our fix that alll,hope will help!
Posted on Oct 09, 2012
Hey phill i have an aiwa nsx a j700 and it won't power on could it be a fuse?
check out the power cable first then proceed to the power unit of the system and most likely problem exists there. best of luck and careful
Jul 29, 2014 | Aiwa NSX-AJ100 CD Shelf System
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
Accidentally my aiwa 3 cd changer fall down and damaged
Same model is not in stock however new models in Aiwa and Sony are very nice in music.
Jan 25, 2009 | Aiwa NSX-DS55 CD Shelf System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
53 people viewed this question
 Grubhead
Grubhead
