Turning on the TV, can hear the sound of the program but the screen has no picture and begins to fade. Brand new tv, was working last night.
The complaint is panel, panel is very costly spare on lcd tv.
Posted on Nov 04, 2012
5 Suggested Answers
SOURCE: Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Posted on Jan 03, 2008
skotkolr
  • 558 Answers
SOURCE: monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Posted on Feb 04, 2009
  • 1684 Answers
SOURCE: My monitor was working fine last night. I got up
It sounds like you have a monitor with a common problem. After a few years some LCD monitors willblow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. When the capacitors blow out they also damage the driver MOSFETs. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. I am putting together a step by step repair guide for this series of LCD monitors, it should be up by 07/11, check my web site for the guide. Repair parts kits are also available for $16.95 If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you are not going to repair it we will buy it from you for parts, we pay $30 for dead/as-is units.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 11, 2009
  • 541 Answers
SOURCE: Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Posted on Jan 01, 2010
My picture fades out, I have sound can't change the channels?
soundslike you need a new TV or get this one repaired .
Aug 08, 2016 | Televison & Video
Turn on TV, sound from program but no picture, just a bright screen. Picture begins to fade. Brand new led TV, was working perfectly fine last night.
Your TV have problem with its T-Con board. T-con board is one which drives the LCD Panel Pixels in rows and columns. As you didn't specified the brand and model number its not possible to give you the exact picture of T con board How its look like. You can find this board On the top center of the tv. Which will be covered with metal case or aluminium foil to avoid external interference. Here i have added a picture of T- Con board which used in Led Tvs.
Nov 04, 2012 | Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Picture Fades Away
honestly a tv that old, there probly wont be any parts to fix it. New tvs that size are about $999, go look at a new tv you will be suprised.
Jul 16, 2009 | Televison & Video
My brand new tv lost the picture last night.
This commonly happens when the power inverter board goes out. It powers the LCD or PLASMA screen.
It's a common problem for all brands of TVs. Mine was brand new and it lasted for 4 months until I had the power inverter board replaced.That was back in Nov of '08. And it's still working today.
If you have the warranty, use it. The board itself cost between $75-$250, depending on the size of the screen.
I hope I answered your question. Please rate me. :)
Mar 20, 2009 | Sanyo Televison & Video
NO PICTURE CAN HEAR SOUND BUT SCREEN BLACK
If the picture faded over time and then went out completely....you have a bad digital main board. Hope this helps.
Jan 01, 2009 | LG 37LC7D 37 in. LCD HDTV
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Samsung TV stopped displaying picture
No picture but sound can mainly be of two problems, most of the times it is caused by a faulty vertical deflection ic, you can diagnose this by slightly increasing the screen voltage by turning the screen control on the LOT, a horizontal line will appear if the vertical ic is shot, and the other problem is the CRT base, but this is less common for shot base won't go off at once, it will show picture faded in the beginning. Now another problem could be the horizontal output transistor, if the tv has a high power sound output, the sound power supply will come from smps itself instead of from LOT, check that too, to confirm this, check if the CRT filament is glowing. Good luck.
Jan 17, 2008 | Televison & Video
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
