Question about Janome Hello Kitty 11706 Mechanical Sewing Machine
Janome 802 Sewing Machine Manual - Janome Hello Kitty 11706 Mechanical Sewing Machine
SOURCE: Manual
I have uploaded the manual to rapidshare, here is the link.
http://rapidshare.com/files/134523596/sewing_machine_instructions_Harmony_2041__English_.pdf.html
Posted on Aug 03, 2008
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: manual for Janome Harmony 2049 sewing machine
www.janomestuff.com answer it all
Posted on Sep 16, 2009
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
I am looking for a free download for a Janome MyLock 234 overlocker service manual. Where can I get this?
Service manuals are not normally free. $9.99 will get you one. Instruction manuals are free.
Janome Mylock 234 Sewing Machine Service Manual. Here are just a ...
https://www.pinterest.com/pin/515451119835333916/
  1. Cached
Janome Mylock 234 Sewing Machine Service Manual. Here are just a few examples of what's included in this manual: * Feed timing. * Upper knife timing.
[PDF]MyLock 234
janome.com/siteassets/support/manuals/retired/serger/inst-book-234-en.pdf
  1. Cached
Page 1. Page 2. TABLE OF CONTENTS. PREPARATION. Names of Parts , , . . . , . . . . i . , . . . . . . . . . . . e . , . , . . . . . 2. Standard Accessories . . . . , . , . _ .
Service Manual: Janome 234D (PDF Copy) - Janome Sewing Centre
https://www.janomesewingcentre.com.au/.../instruction-manuals/service-manual-jano...
  1. Cached
  2. Similar
Has your beautiful sewing machine started sounding a bit sour? With the official ... Covered in the Service Manual for the Janome My Lock 234D is: SERVICE ...
Service-Manual.net - Janome Service Manual Downloads
www.service-manual.net/ashop/Janome-Service-Manual-Downloads-All-Models.html
  1. Cached
  2. Similar
To facillitate ease of locating your model, you can use the drop down menus below to navigate our current inventory of Janome service manuals. Your model ...
Sewing Machine Janome MyLock 234 Instruction Book - ManualsLib
https://www.manualslib.com > Brands > Janome Manuals > Sewing Machine > 234
  1. Cached
View and Download Janome MyLock 234 instruction book online. MyLock 234 Sewing Machine pdf manual download.
JANOME MYLOCK 203 INSTRUCTION BOOK Pdf Download.
https://www.manualslib.com > ... > Janome Manuals > Sewing Machine > MyLock 203
  1. Cached
... 203 instruction book online. MyLock 203 Sewing Machine pdf manual download. ... (88 pages). Sewing Machine Janome MyLock 213 Instruction Manual. (41 pages) ... Sewing Machine Janome MyLock 234 Instruction Book. (41 pages).
Janome 234 Manuals
  1. Cached
View online or download Janome 234 Instruction Book, Service Manual. ... We have 2 Janome 234 manuals available for free PDF download: Instruction Book, Service ... Brand: Janome ' Category: Sewing Machine ' Size: 3.36 MB ..... Janome Decor Excel 2 5024 · Janome 2200XT · JANOME MY LOCK 204D · Janome 2149 ...
manualsoncd.com/product/mylock-234-sewing-machine-service-manual/
  1. Cached
Product Description. Janome Mylock 234 Sewing Machine Service Manual. Here are just a few examples of what's included in this manual: * Feed timing.
Janome MyLock 234 overlocker service manual Google Search
Jul 12, 2017 | Janome Sewing Machines
How do you thread a model 802 overlocker
Unfortunately, the only model 802 I can locate is a Janome sewing machine.
Search the internet for:
Make Model manual
or contact manufacturer support.
Nov 24, 2016 | Sewing Machines
I have a Janome 802 swing machibe.I want to uninstall it for detail check and better service and then install it. I'm looking for a prorper service manual
Loosen the top cover the add a couple drops oil at each joint. Do the same for the rest of the machine. Remove the bobbin case and permit the sewing machine to run freely. It may take 10-15 minutes before it begins to loosen.
Feb 02, 2015 | Janome Sewing Machines
My janome 802 sewing machine is giving a tough threading while i sew. How can i solve my problem?
hello can anyone tell me where can i buy a shuttle driver for my janome 802
Jun 28, 2012 | Sewing Machines
Download a Janome (Jem 639) sewing machine manual
Just today  i got out my little janome i bought years ago and it is this model.  There was no "manual" with the machine.  All that came with it is a large 20X14 two sided print out.  I can scan and send this to you with an email address.
Feb 17, 2009 | Sewing Machines
Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
600 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
