Question about Music
I have a vintage Rembrandt 2 channel guitar tube amp model 462 that the 12ax7 tube won't light up. All other tubes light up but that one tube. Any ideas on where to begin?
It is only a pre-amp tube. try putting a different one in....
is it a head? or a combo. I had one that I liked that I sold because I needed the $$$. if you have a pic of the back...send it to thundervert@charter.net. If you don't have any other tubes, let me know. I've got a bunch, and I'll pop one in the mail. If any tube doesn't light up, you've got either a socket or input problem.
best,
Tom
Posted on Jan 24, 2013
3 Suggested Answers
  • 5603 Answers
SOURCE: Have a Crate V50-112.Have had it for 1 year.
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Posted on Feb 02, 2010
  • 5603 Answers
SOURCE: I have a Crate v32
I don't know how you know the tubes are good... It is possible they are microphonic... try tapping them with a pencil (only need to worry about the smaller ones).
Beyond this look for cracked circuit board or bad solder... especially near the control pot leads. This is a common problem. Look for cracks near the booard mounting points.
Posted on Dec 24, 2010
Hello, I own a hotrod deluxe. I take great care for it and never move it. Normally on the clean channel, the volume is regulated by the volume and the master. Today the amp sounded only half as loud as...
Do you turn on standby every time and wait for the tubes to heat up first? If you don't, it can severely damage the tubes.
But a common cause of this could be just old tubes. Like any other piece of technology, tubes get old. If you like to play your amp LOUD then they wear out a lot quicker. You have to replace tubes every now and then. Because I'm not there to check out your amp, I can't give you an exact answer but it sounds like that's the problem. This isn't always a bad thing. You can make the sound of your amp exponentially better with nicer, new tubes. Your amp has 12AX7 tubes. Very common tubes to use actually. I'm not sure what kind of music you play, I'm assuming mostly rock and blues. But here is a list of tubes and reviews on them.
http://thetubestore.com/12ax7review.html
This is how to replace a tube:
http://www.ehow.com/video_4438285_change-pre_amp-tubes-guitar-amps.html
Upkeep on a tube amp:
http://www.ehow.com/video_4438295_replace-tubes-guitar-amp.html
A note he doesn't make in the video is to dust out your amp. I use the compressed dust spray for the inside of computers.
So overall, stop turning up your amp to 11, make sure it's well ventilated and dust it out from time to time. Hope this helped.
Jun 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hi I run a Super Sonic 22 which for me has a sweet spot at 2-3 Volume on the burn channel. I need to run at 4-5 on stage but at this settin it looses the full quality and goes very mushy just like the...
It just doesn't have enough power for what you want. Either get a bigger version amp OR mic it and run it into the PA system where hopefully you have enough power.
Jun 03, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
My new Bugera 333 212 combo has a weird "ringing" noise on the crunch channel. The noise can be heard on other channels too, but it is loudest on crunch. The noise is clearly mechanical, (it...
Microphonic tubes can be detected by tapping them lightly with a pencil. I cannot find if this uses a spring reverb, but if it does, vibrating the cabinet will get a clanky type sound from the reverb tank. This MAY use a digital reverb however which is immune to that. Next thing is to make sure your guitar can't "hear" the output sound of the amp because the strings can pick up the sound and resonate feeding back into the amp. You can detect if this is happening by quickly dampening the strings and see if ringing gooes away. You probably need 6 to 10 feet of clearance between the guitar and the amp OR put your body between the amp and the guitar. ALWAYS set sound level at safe levels. Get a sound meter and go no higher than 90 Db. I know a lot of near deaf musicians whose careers are near over because of hearing loss using too high level.
May 24, 2011 | Behringer Bugera 333212 120W 3 Channel...
I've had the Tonebone Plexitube since January of this year, but have only played through it a couple of times. I recently took it out to really experiment with it and get to know the pedal. Right away...
It sounds like somehow the pre-gain is very high while the volume or post-gain is very low. Try turning the volume high on the effects unit and the gain low, and don't have the amp volume too low either.
May 18, 2011 | Radial Tonebone Plexitube Effects Guitar
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
My amp is making a high pitch noise almost like feed back. I only use the clean channel.When I tryed the other channel it is not working at all. Bad tube?
Bad tube? maybe
Try removing each tube 1 at a time starting at the first preamp (12ax7) If the noise stops after a particular tube is pulled replace that tube with a known good tube. Shut down the amp between tube pulls, Power tubes don't usually cause this problem but I'd pull them anyway,just remember they get very hot.
Make sure all tube shields are on and replaced after tube pull test
The most common cause of oscillation is a open or leaky filter cap,this would require a cap job and unless you have a good knowledge of tube electronics and the voltage dangers present,I wouldn't suggest doing it yourself.
Also if the output transformer was replaced or rewired or the negative feedback circuit was touched oscillation could occur also.
Make sure your guitar cables are in good shape, a cable with a bad shield can cause problems too.
Excessive noise can occur when one of the 1/4" input jacks shorting bars doesn't make contact to ground. A duumy plug would confirm this but you could also plug two guitars with good cables, into each input and see if the oscillation disappears.
Hope this helps
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Channel one doesn't work
The 12AT7 is usually the driver tube for the tubes before it ( the input channels ). It can also be the driver for the reverb or tremelo channel. I'm not sure what model of amp you have or the manufacturer but there are plenty of places to look on the internet for info. http://duncanamps.com/index.htm is a good place to start. If you can't find the schematic for your amp try and find one that is similar to give you some ideas. If you don't have the basic tools like a volt/ohm meter and a capacitance tester. You might have to consider a pro to look at it. You will be looking for resistors and capacitors in the same circuit as the tubes that you originally mixed up. If its a hybrid solid state/ tube amp you will also need a transistor tester. Of course good soldering abilities are necessary and ABSOLUTELY do not work on the amp while it is plugged in and make sure you properly discharge the filter capacitors in a safe and proper manner before touching the circuit. All the info you need to sucessfully do it yourself is available at the library or on the net as long as you are confident in your abilities and first and foremost work in an absolutely informed and safe manner. Hope this helps.
Jul 15, 2009 | Music
Music Logo
266 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
