I seems like my Honeywell Chronotherm III doesn't let the fan run after the oil burner stops. I would expect the furnace fan to continue running for a couple of minutes even if the temperature does run up a bit. Is the fan run time adjustable or might there be a problem with this t-stat?
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem...
(More)
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem exists- Thanks, Richard
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on...
(More)
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on "Leave" at 58 degrees at 7am and "Return" at 66 degrees at 4pm. The unit starts heating the house at 12noon to move it 8 degrees. According to the directions it should only kick on a max of 24 minutes per degree not 4 hours - any suggestions?
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and...
(More)
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and humidity. what could be wrong?
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to...
(More)
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to outside temp,and the blower turns off ,the humidifier water still comes into humidifier and wont shut offf unless i turn humidistat to off position
