Question about HP 0x2x16 kvm svr cnsl g2 vm cac sw af618a
Manual KVM AF618A - HP 0x2x16 kvm svr cnsl g2 vm cac sw af618a
Looking for manual for 8 port usb/ps2 kvm TK-803R
Hi
I don't think this is exactly what you want ut is nearest I can find at the moment:
http://19inch.jp/trendnet/kvm/document/EN_Web_QIG_TK-803R_1603R_081409.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Trendnet TK 803R KVM switch 8 ports...
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
Hot key combination to switch Bytelan KVM
Try SCROLL-LOCK, SCROLL-LOCK, then UP-ARROW (or '1') or DOWN-ARROW (or '2').
Apr 02, 2010 | Protec Microsystems Bytelan KVM/4 KVM...
I have a justcom jc102cpa kvm switch and I need the hotkeys
KVM <====> Keyboard, Video, Mouse
Note that 'AUDIO' is not part of the "KVM" switching feature.
Dec 11, 2009 | JustCom JC-102CPA KVM Switch
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
Users manual for KVM model ''MT-471s Auto KVM''
turns out if I double tap and hold the scroll lock key, the kvm rapid beeps and while in this mode, I can hit the numbers 1 to 4 to pick the port I want to connect to.
The double tap on the scroll lock suggestion was sent to me by a fixYa responder. Thanks,
Mar 19, 2009 | Computers & Internet
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
Manual for the Protec Bytelan KVM/4
The switches are used when cascading more than a single BYTELAN KVM. It specifies the scan rate, and which KVM unit the keyboard and mouse are connected to. For a single KVM, use the default settings. SW1 SW2 Scan Rate ---------------------- ON ON 2 seconds OFF ON 10 seconds ON OFF 20 seconds OFF OFF 40 seconds SW3 NOT USED SW4 ON For KVM unit with KB/mouse OFF For other KVM units w/o KB/mouse, If your power supply isn't adequate, it may cause your KB/mouse problem. It should be 9VDC with at least 500ma. Hope this helps.
Aug 20, 2007 | Protec Microsystems Bytelan KVM/4 KVM...
HP 0x2x16 kvm svr cnsl g2 vm cac sw af618a Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
