Question about Brother BRTPT65 PT-65 Label Maker Printer
Can't change the font style & size on my Brother PT-65 Label make
For some reason my Brother PT-65 label maker is locked in one mode and I cannot change the font style or size anymore. Any suggestions? is there a reset of some sort. Anyone else with this problem?
Thanks
  • Anonymous Apr 20, 2009
    Stuck in small font-size even though the indicator allow me to select other sizes, labels print in small size format
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
  • demap Dec 09, 2010
    The printer is stuck in double line mode, although it indicates that it is in single line mode. When you switch between the two modes, pressing `enter`and `clear`, it will go back to the single line mode, and you can change the font size again.
    New Friend:
The reason the unit is printing small despite selecting a large font is because you have a carriage return (that little curved arrow) at the end of the line. The unit is expecting a second line after the return. Two line prints only allow the small font.
Do this: backspace to remove that carriage return.
Posted on Jul 06, 2013
Don't know if you were aware of the fact that what you see on the screen does NOT change - in spite of what you are programming into your printer. So when you change font size - hold code botton while you press the "&" sign. Then just print. We kept waiting for the lettering on the screen to change... It doesn't. Same for selecting frame style. :-(
Posted on Sep 12, 2012
You have to push 'Code' and then 'Repeat' once you have selected your desired font size in order for it to actually change.
Posted on Aug 29, 2012
I am having this problem, too. I change the size and other variables in the usual way, but it prints out the smallest font size with no additional formatting anyway. Very frustrating.
Posted on Oct 09, 2011
How do I change the font size on my lavel maker
If you go into the menu, and you go down to font, hit enter. It should bring up size, style etc. If not, please tell me.
May 11, 2010 | Brother P-Touch 1180 Label Printer
How do i change the font size on my P-Touch ModelPT-1880?
By pressing function button (Fn) and the number 1, you will get the choice between Large, Medium, Small and Max.
Also, you can press Fn, tap the left or right array until you get "Size" in the display, and then press OK to enter the size menu.
Jun 05, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
CHANGE FONT
The printer can be stuck in double line mode, although it indicates that it is single line mode. Switch between the two modes, pressing " enter" and " clear ", until you are in single line mode again. Now you can change text size again.
Jun 03, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Prints only in smallest of 5 font sizes. Had use of all 5 before
on PT-65 hold down the code button and press & ; each time you do this the font selection ( there are 5 of them) moves to select your font
Apr 02, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT 65 Label Maker
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Dec 31, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Changing font size
I just wasted 20 minutes to get the font size changed. Press Code and then the & you keep pushing the & and it will toggle through the numbers 1-5 (5 being largest)
Dec 21, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Changing font on PT-65
Hold down the [Code] key and press the [&] key to change text size.
There are five different size/styles of text shown at the top of the screen. Keep holding down the [Code] key and tapping the [&] key until the little arrow is pointing at the size you want.
(It doesn't change the display on the screen, so you'll get to play and print out lots of tests - in the name of science!)
Jul 22, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
May 26, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
6,788 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
