Question about GE JKP45 Electric Double Oven
GE TrueTemp JKP45 double oven will not self clean / lock
When trying to self clean the oven (top), I push START, and the display says "door" and also flashes "locked" at the bottom of the display. Then nothing happens. I try to hit cancel, but the display just clears and the clock displays, but "locked" is still on the bottom of the display. I cannot even use the oven, as none of the other features (i.e. Bake, Broil,...) will now work.
  • Anonymous Feb 02, 2009
    my panel for the upper oven says locked and the top oven is not working now
  • Anonymous Mar 25, 2009
    I used the self clean program. It finished but now it is permanently locked. I then had it cycle again through the self clean, but it still remains locked. I cannot use the oven.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
I am not able to get the cleaning in my self clean oven to start
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 24, 2010 | GE JKP45 Electric Double Oven
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Need to know how to operate the ''self-cleaning'' function of the GE TrueTemp Oven.
Take the chrome racks out of the oven
make sure oven is COLD
move lever on door to the right
turn dial to CLEAN display should say 4 hours, but I've found 3 hours is plenty, reduce by touching Cook Time
YOU WON'T BE ABLE TO OPEN THE DOOR FOR 3-4 HOURS.
Jan 19, 2010 | GE Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Both door will not lock when i start the self cleaning
u have to push the grey round butten that said start by the clock
Oct 22, 2008 | GE ZET2SMSS Double Oven
General Electric JKP45 Double Oven
Don't know why repairman couldn't order parts you have your model #. The model # is the JKP45WV1WW, The part # is WB26K5030 for the lock motor.
Jun 30, 2008 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
206 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
