Question about Sylvania 7" Mini Tablet
My tablets touch screen function& menu button not functiong
Touch screen not working, menu switch is not functioning....?
Can i buy a new screen for my icraig tablet cmp759
Replacement Touch Screen for iCraig Craig CMP756 Dual Core 9 ...
www.actablet.com/replacement-touch-screen-for-icraig-craig-cmp756-dual-core-9-in...
  1. Cached
  2. Similar
Digitizer Glass Capacitive Touch Screen Panel Replacement for iCraig Craig CMP756 Dual Core 9 Inch Android Tablet PC Features: Brand new, original touch ... Missing: cmp759
Amazon.com: Touch Screen/Panel Digitizer Glass Replacement Parts ...
https://www.amazon.com/Screen-Digitizer-Replacement...Tablet/dp/B00J09P2SM
  1. Cached
Buy Touch Screen/Panel Digitizer Glass Replacement Parts for CRAIG CMP738b 7" Tablet PC: Screens - Amazon.com ? FREE DELIVERY possible on eligible ... Missing: cmp759
LCD Display Screen Replacement for Craig CMP745e iCraig ...
https://www.amazon.com/Display-Screen-Replacement-Craig.../dp/B00LTB655S
  1. Cached
There are two layers of screen for a tablet. The one on the top is a touch screen, which works for the function of touch. The other below is the LCD screen, which ... Missing: cmp759
craig tablet cmp759 replacement screen - Buy Wholesale Phone ...
m.totobay.com/wholesaletags/craig-tablet-cmp759-replacement-screen/
  1. Cached
Items 1 - 20 of 5498 - craig tablet cmp759 replacement screen - Wholesale craig tablet ... Craig tablet 746e screen replacement icraig CMP759 screen panel ...
Craig Electronics Inc.
https://craigelectronics.net/
  1. Cached
Whether you are looking for audio products like our Bluetooth/WiFi Speakers, or portable products like our Action Cameras, and Tablets, we bring you the ... icraig tablet cmp759 Google Search
Feb 01, 2017 | Tablets & eReaders
Last Gmail I looked at is locked on screen on right side.
Close GMail first by swiping it off the running apps screen.
Uninstall GMail using the *Uninstall* option in:
Settings > Apps > Downloaded > GMail. Touch GMail and you will get another screen with an option to uninstall it. Touch the uninstall button and it will uninstall.
Then go to the Google App Store and download it again. It sounds like the Mail app got corrupted somehow.
May 11, 2015 | Tablets & eReaders
Printscreen not working ipad
To capture screen shot or print screen on your iOS (iPhone, iPad, iPod touch):
1- Press and hold menu button (the menu button at the bottom of your device)
2- While the menu button is hold down, press the power/lock button (the button that you use to lock the screen at the top of your device) Read more: How to capture screen shot or print screen on ios iPhone, iPad, iPod touch ' loymovie
printscreen-not-working-ipad-fsa0em3gpfye3khtm1m3hcbs-2-0.jpg printscreen-not-working-ipad-fsa0em3gpfye3khtm1m3hcbs-2-2.jpg
How to capture screen shot or print screen on ios iPhone iPad iPod touch...
Jan 10, 2014 | Apple iPad Tablets & eReaders
Touch screen function not working but mouse working
try to shut it off. and turn it on after 10 sec. dont touch the screen when the unit is booting.
Sep 13, 2012 | Lenovo ThinkPad X60 Tablet PC
New playbook. Welcome screen tells me to swipe to continue to setup wifi. I swipe the screen and nothing happens
try to soft reset it by engaging the reset button ..If it has such a button it should be hidden in a hole on the side and need to be pressed until restarts ..(it should be powered and on when you do this) ..
If there is no button ..it means it has something wrong with the touch screen function ...and you should try to see if the screen is not out of focus..and try to swipe it in a certain point ..and if it is indicated..try in near by locations ...If you manage to make it start you should look in the main menu for screen calibration ..and engage it ..this should make the touch screen work proper again .
In worse case you will need the firmware and reset it to factory settings ..
Dec 08, 2011 | Blackberry PlayBook Tablet PC
Touch screan it doesn't function
have you installed tablet pc edition os ?
Apr 01, 2010 | Gateway M275 Tablet PC
How to i get the touch screen working
The touch screen function is controlled by software and drivers. You'll need to start by making sure that you have the correct tablet software installed on your machine, and you may also need the correct WACOM drivers.
You can go here and download the software for your tablet and see if this works for you:
http://www.wacom.com/downloads/drivers.php
Mar 04, 2010 | Gateway M275 Tablet PC
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Sylvania 7" Mini Tablet Logo
21 people viewed this question
Top Sylvania Tablets & eReaders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Sylvania Tablet and eReader Expert? Answer questions, earn points and help others
