Question about Toshiba 50HM67 50" HDTV
I have a toshiba 50hm67 the picture is prefect dont think the build is bad, but i have a humming coming out of the tv what could that be and how can i fix it.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If it is a high pitched or even fan like sound it may be the color wheel in that set which if I remember is not sold except with a complete light engine, do some research on that model for color wheel.
Posted on Nov 05, 2012
  • 2920 Answers
SOURCE: Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Posted on Feb 01, 2009
SOURCE: I nees a cooling fan for a Toshiba 50HM67 50 inch
trucker I found this website....http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1089868%2DTOSHIBA&Show=ExtInfo hope it helps
Posted on Aug 22, 2009
Testimonial: "Thanks for the tip!"
welcomejee
  • 10594 Answers
SOURCE: I recently replaced the lamp
This is problem of DMD chip that generates picture/ image in this tv and DMD chip is not available separately so complete light engine will be replaced to fix this issue. It is bit costly fix.
Click Discount-Merchant link to view light engine images and they offer required light engine for $330 and local tv repairman will help you to replace it because it needs expertise and skills.
Hope these info will help you.
Thanks.
Posted on Sep 11, 2010
SOURCE: I have a toshiba 56mx195.
www.tacp.toshiba.com/tacpassets-images/.../72mx195_om_e.pdf
Above is your owners manual, below is your service manual.
https://www.completeservicemanuals.com/toshiba/dlp-projection-television/cat_41.html
These two training manuals below, these manuals will show you how they all work and go together, use these and the service manual, and you will be able to troubleshoot and hopefully repair your issue. usually when this type of thing happens, it is a Panel PCB, that is faulty, and usually that board can be replaced. However before you start doing anything you must, must start at the Power Supply and make sure that is 100% A OK, as if it is NOT, then nothing else can be...
www.scribd.com/.../7520950-Toshiba-CN27E90-TV-Technical-Training-Manual -
www.scribd.com/doc/.../Toshiba-TV-Service-Manual-CF19A21
Posted on Sep 22, 2010
fieldy14
  • 456 Answers
SOURCE: i have a toshiba 50hm67. the lamp went bad so i
Have you reset the lamp use timer?
Posted on Jun 24, 2011
My toshiba 50hm67 has no sound
If you still have picture, and the sound was working before this--you may have lost the audio amp chip. I hope you are not running a bunch of external speakers on the tv here--this WILL kill that chip !!
Apr 08, 2014 | Toshiba 50HM67 50" HDTV
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
The picture won't come on and when I push the power button it says lamp is not working
The tv "LAMP" LED light indication flashes or stay on.Ur tv the projection lamp life are over.Ur tv require a new projection lamp.
Jan 19, 2011 | Toshiba 50HM67 50" HDTV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
Recently replaced blown lamp for 50HM67 50 inch tv. Now have picture but clarity is off. Picture / screen words are very blurry. Toshiba referred a local repair company who mentioned that the problem...
If the picture was good before the lamp blew, there might be dust/splatter on the window in front of the lamp. Pull out the lamp assembly and look at the small square glass window that the light shines into. It should be clear and clean. If it is not, clean it gently with isoprophonol alcohol or screen cleaner.
By the way, there is no such thing as convergence adjustment on DLP TVs.
Sep 09, 2009 | Toshiba 50HM67 50" HDTV
Jun 21, 2009 | Toshiba 50HM67 50" HDTV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Toshiba 50HM67 50" HDTV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
