Question about TruTech PLV1615T 15 in. LCD Television
Kishu tv i have a kishu 20in lcd tv.the stand wont make the tv stand up straight and the back of the tv doesnt seem to have a place for a bracket.any ideas?
How do I remove a sony 52" bravia xbr from the stand
I can't say for sure, but I have an KDL 46XBR5 and it may be similar to the 52". The stand is most likely being held in place beneath the back cover like the unit I have.
After you unplug the tv, lay it on a flat surface with a very soft clean blanket so you don't scratch it up. Place the television face down with the stand facing you.
Now if you look very closely, you may see little arrows (they look like this : -->) and little triangles all over the place. Disregard the triangles altogether, but remove all of the screws that have little arrows (again, they are the ones with he "->" pointing to the screw. There could be anywhere from 16 to 24 screws.
Make sure you put them back exactly where they came, there are usually different sizes). A piece of cardboard with a rough diagram drawn with marker helps, just push the screws into the cardboard where they line up on the tv.
Once you remove the back cover, you will see the stand has two large brackets screwed into the back of the television. They are vertical from the bottom.
I have attached diagrams showing the removal of the back panel as well as the bracket for my KDL46XBR5. YOURS MIGHT LOOK DIFFERENT but should be somewhat similar or at least give you an idea to go by
Note: If I am not mistaken, there are two black insulated copper ground wires connected to the bracket. If you disconnect the brackets, you will need to figure out where to reconnect these ground wires most likely or remove them altogether.
Hope this helps
Mar 26, 2013 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have aphillips tv, model number 42pfl7603d/10. The stand which it sits on at base of tv has broke, I'm looking to find where I get a replacement one. My walls will not support brackets for it
The only place I found that has one is in the UK
http://www.ebay.com/itm/TABLETOP-STAND-FOR-PHILIPS-42PFL7603D-37PFL7603D-37PFL5603D-42PFL5603-LCD-TV-/360506039050?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item53efd59b0a
Dec 06, 2012 | Televison & Video
How do I adjust the stand
The stand does tilt the TV forward but you can adjust it. Remove the entire stand bracket from the back of the TV with a philips head screwdriver (6 screws). Then use a 1/2" wrench to loosen the two adjustment bolts on the wings. Straighten the angle on the wings, retighten the bolts, and reinstall the bracket. Then the TV will stand straight up.
Jan 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Vertibra 1 lcd tv stand
the best place for mounting brackets is MAT electronics out of california.very reasonable on lots of items....BB
May 14, 2008 | Televison & Video
Stand
How do I remove the stand?
Apr 13, 2008 | Toshiba Televison & Video
TruTech PLV1615T 15 in. LCD Television Logo
167 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
