My hcl TFT 1560ps no light on screen but disply on
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
How to fix broken TFT background lighting?
I tougth it is better if you replace your TFT in one package. Too much time to be cost if you try to fix the backlight. But you can try this video http://www.youtube.com/watch?v=w4v20PyomuU after you sure that your backlight is the problem by installing another undefected TFT
Aug 15, 2014 | Samsung R65 Notebook
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
Dear sir my hcl tft lcd not provide me sound
Use your motherboard model name to find your audio drivers from the internet or specify it together with the operating system type at fixYa so as we can help you find where to download.
Apr 24, 2011 | Computers & Internet
I use 17" TFT LCD monitor of HCL make. there is a blue straight line appears on my screen. please suggest what to do to resolve the problem.
change your screen resolutions two~three different settings and a different computer - lf the line appears in same position, it's most likely bad monitor.
Sep 22, 2010 | Computers & Internet
Dear sir i have a hcl p4 pc motherboard model ecs p4m800pro-mv1.0a it can not start when i start system system boot only one beep show within 3 second show disply then system shutdown plz tel me how to...
hi you could check to see if your hard drive cables arent loose and your dvd drive cables open it up and dicharge any static from your body by touching steel frame first before you touch anything inside the pc
Aug 19, 2010 | Computers & Internet
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
