My kenwood aplifier krf-v7060 turns into standby mode after few seconds after switched on
THENTHEREWER
  • 131 Answers
SOURCE: I have a brand new
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
Posted on Nov 29, 2008
  • 4234 Answers
SOURCE: my kenwood krf-v4060d reciever on/off switch is faulty.
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Posted on Dec 09, 2009
SOURCE: my kenwood dts amp krf-v5050d
Probably the problem might be the IC STK 413-010A.
Posted on Dec 07, 2010
cyberfast
  • 155 Answers
SOURCE: I have a Kenwood KRF
i'm not the perfect expert in this but did you try removing all speaker,rca,s video, etc from the back and seeing if something maybe back feeding to the receiver. the red light blinking usually means its detecting a short somewhere and it goes in a fail safe mode to prevent more damage. if it stays on with everything disconnected the problem is with something else. try them one at a time to isolate the problem. hope this helps thank you.
Posted on Jan 01, 2011
jdvillanueva
  • 2098 Answers
SOURCE: The problem I ran into
Hi amit2817,
Your unit gone to overload that caused the subsequent shutdown. To isolate the input and speakers from fault, disconnect all input cables and speaker wire from the unit then turn it on naked. If the symptom still there then this is a clear indication that the fault came from the unit itself. Most common caused of this problem is the sound output circuitry and the power supply. Most common affected parts in the output section is the output IC/transistor(mounted in the large heat sink). It will fail because of exposure to excessive heat due to frequent high volume and or because of aging. Bad solder joints is also to consider to this section and also to the power supply section. Because of heat build up, most of the joints dried resulting to poor flow of the supply and trigger the over current(overload) protection circuit. Leaky electrolytic filter capacitor is also one of the factor in this fault. It will produce an out-of-regulation to the power supply output. You must have a capacitor checker to determine its condition. Sometimes it has a bulged/dome at the top but not all.
If you don't have necessary tools and test instrument and can't troubleshoot the symptom, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
My ken wood krf v5050d automatically goes back to standby what is the cause
hello! i need help with this, i have the same amp Kenwood KRF-V5050D it seems that it had a short circuit on the speaker terminals, close to the 2 12v relays wich are close to each other and the 2 transistors kia 7812 and kia 7912 was turned black, i have replaced them, and i have disconnect the 2 big IC but the amp still does go in the protection mode, but when i disconnect the 2 transistors kia 7812 and kia 7912 the amp does stay on. i have checked almost everything and it seemed to be good. i have checked every transistor and replaced some capacitors, but i have not replaced the 4 big capacitors, with all the 0.22j resistors and all the terminal relays and the 2 big ic disconnected the amp still goes on protection mode. i had this amp returned from ebay and the buyer is waiting for it to be repaired, i would aprecciate any help.
ujka.pjetracaj@hotmail.com
Kind Regards.
Oct 07, 2013 | Kenwood Rc-r0511 Home Theater Receiver...
No power
One has to open her up and check for aged or swollen caps on the
power supply.
Sep 08, 2012 | Kenwood Audio Players & Recorders
I have a kenwod krf-v5050d amp (old I know). I have my blu ray hooked up via an optical cable however I can not get any sound through the speakers from it. I know it shouldnt be the speakers or the amp...
xjackdeth,
All systems with multiple audio/video inputs for each connection must be told what connection you want it to play. Most likely your selected choice of input is set to an input other than digital. I included a link to download the manual for your Kenwood model; see page 9 for "Input mode settings".
First use the input selector knob to select the input you are using for the blue ray player, then press the input mode button to select digital auto; the Kenwood should take a few seconds to switch over and then you will be in business.
http://audio.manualsonline.com/manuals/mfg/kenwood/krf-v5050d.html
-Chris
Jan 09, 2011 | Kenwood Unity System
I have a Kenwood KRF v5200d audio video control center that worked great for 2 years . It is just out of warranty and is now giving problems. It turns on for about 15 seconds and then cut out and goes into...
Jan 01, 2011 | Kenwood Audio Players & Recorders
My kenwood krf-v4060d reciever on/off switch is faulty, it stays switched on for a few seconds and then switchs its self off.can i get a replacement ? i have had not much luck here,any suggestions !
Dan
Dec 09, 2009 | Kenwood Audio Players & Recorders
KRF-5030D i stand by mode
Does it go into standby when it's in another mode like : Cd or Video 1 or tape?
When you state that you checked the power amp IC's , how so did you do this?
Thanks n' let me know.
Feb 08, 2008 | Kenwood KRF-V5060D Receiver
 Grubhead
Grubhead
