Question about Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum
I have a small canister type hoover vacuum and I would like to open it because the cord rewinder it jammed. I have removed all 4 screws but still can't seem to separate the two pieces. Am I missing something?
    President:
  • 389 Answers
I may be able to help, but would need to know what model your machine is. Re-post, giving as much detail as possible and we'll see...
Posted on Feb 07, 2009
My hoover wind tunnel cord is all the way out; will not rewind. Can I fix it myself?
I took off the dust canister and then the 2 Phillips screws on top of the rewinder. I was searching how to get at the rewinder so I took out the HEPA filter and holder. I then pressed down on the rewind leaver and it rewound. I am not sure why but maybe what I removed was putting some pressure on the rewind mechanism or I just had good luck.
Oct 27, 2012 | Hoover UH70120 WindTunnel TSeries Rewind...
Hoover s3670 opening the vacuum case
there are screws under the power switch and the cord recoil switch. the switches pry off lengthwise. once the switch covers are off you will see the rest of the screws. it was pretty straight forward from there.
Jan 02, 2012 | Hoover S3670 Bagged Canister Vacuum
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Sep 17, 2009 | Hoover Vacuums
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
Power Cord is Jammed
Thanks Joe for finding the location of that fifth screw. I've taken some photos to help out anyone else who might be having this issue.
Its on my blog here.
Jul 06, 2007 | Hoover S1361 Bagged Canister Vacuum
Hoover S3330 / S3332 Straight Suction Telios Bagged Canister Vacuum Logo
198 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
