Question about Bose Acoustimass 16 Speaker
Left Channel Not Working.
I have a Bose Acoustimass 16 system. I get no sound out of my left channel. I have plugged the speaker in other channels and it works, and I have tried all the other speakers in the left channel and none of them worked. Thanks. Adam
  • jkanchors Feb 01, 2009
    Same problem.  I have checked all connections, switched speaker to verify that speaker itself is working, unplugged all components for 30 minutes to reset.  Still no left front channel.  Even went through Bose setup disc process which tests each channel for correct hookups.  No sound.  Help!
    Brigadier General:
  • 8,546 Answers
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Posted on Apr 28, 2009
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Hi, I bought a Bose acoustimass 16 - 6.1 channel, iam curious to know which receiver is suitable for that.
I would get a receiver that puts out a little less power than the speakers can handle. This will prevent you from blowing them by sending too much power to them, but will still send enough power to make them sound good.
An example would be, if you're speakers have a combined power of 500 watts get a receiver around 495 watts or a little less.
May 03, 2011 | Bose Acoustimass 16 System
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
No sound from centre speaker on my Bose Lifestyle 8 series 2 system. I've checked leads and speakers by swapping them around. If it is the Acoustimass module which units are compatible?
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
Sep 22, 2009 | Bose Lifestyle 28 System
Dead left channel on Bose Acoustimass 6
Hello
This is not so much my expertise, but i wouldn't say that is is a through away. I had a dvd player which did exactly the same, but my warranty was just over, so i had a look at it and found that if you follow the power line on the circuit to the channels of your speakers(You can easily find it) you can check if the left channel's capacitor seem to be broken(You can usually see it) and then just replace it. Otherwise it could just as easily be a one of the ic's that broke(You can see this easily). I would not through it away, just take it to any electronic repair shop close to you, if your problem is what i mentioned it would not be expensive at all to fix>
Hope this can help you.
Sep 13, 2009 | Bose Acoustimass 6 III System
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Bose acoustimass 15 series 1 channel loss
Sounds like you may have a blown output transistor or chip, which generally show no external signs of damage. This would take an experienced technician to find and fix, and I commend you for knowing to check the speakers, receiver and cables through substitution! If you're handy with a soldering iron and can find the parts, try replacing the output transistors or chips in question. These are what usually fail in audio power amplifiers - also check any power resistors for opens - some of them are designed to act as fuses to protect the more expensive components.
May 21, 2008 | Bose Acoustimass 15 System
Bose Acoustimass  16 Speaker Logo
457 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
