Question about Oster 6854 14 Speed Blender
Broken blender The base of my blender will not turn, it have a square pin with a silver ring around it that is suppose to spin, the light comes on for each setting but when I press the on button nothing happens. There is no noise or anything. I also turned the square pin to make sure it moved freely, that was fine.
4 Suggested Answers
SOURCE: Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Posted on Aug 17, 2009
SOURCE: The blender coupling on my
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Posted on Oct 01, 2009
mc1bean
  • 3053 Answers
SOURCE: how change the square drive
Hello, carolina
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Power light is blinking and the blender will not work
Align the arrows on lid and handle, and latch it down before you put the pitcher on the base and spinning it to lock it in.
Mar 18, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
My daughters blender leaks between the jug and the base Is there a seal missing tks
There is supposed to be a flat rubber ring that goes there, at least there is on my blender.
May 30, 2011 | Blenders
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
My Blade Base Won't Come Out
gently tap the base with a rubber mallet or even the sole of a sneaker. Work your way around and it will come out.
Sep 13, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Oster 6854 14 Speed Blender Logo
121 people viewed this question
Top Oster Blenders Experts
Bruce Showalter
Craig Butler
Craig Butler
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
