Burnt by power surge - Televison & Video
  • 8,617 Answers
Any type of power surge most certainly took out the Power board for sure and possibly the main board too depending on the type of power surge. You can get replacement boards from www.tvcircuitboards.com
Posted on Nov 04, 2012
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
Power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Aug 09, 2008 | Toshiba 32A43 32" TV
Hi there my name is Larry from Mich ,I have a estate electric dryer model Tesco640po serial ms0808710 ,I had a power surge and the dryer quit working it does turn on but only stays on if I hold the start...
The key is "Power Surge" you have no idea what got burnt. I've never heard of the brand is it expensive. Might need to get a replacement.
May 20, 2014 | Dryers
My Panasonic DVD recorder won't turn on after a power out. Another user says that this is common, it may be a burnt diode or a damaged power supply. WOULD TURNING THE POWER STRIP OFF RIGHT AFTER THE POWER...
If the power supply has already suffered the brunt of the surge, it could be an expensive repair, possibly not economical.
Of course, you can submit this recorder to a service centre, and obtain a quote on any repairs/board replacement required, then make a decision afterwards on that basis - yes or no - it's up to you what you do.
Sorry to say the power surge has quite likely destroyed several components in your DVD recorder's PSU beyond economical repair; it would not just be a 'burnt diode'.
However, in the future, if you are worried about likely surges occurring again, you can always switch units off at the power point when you aren't using them (example, overnight when you go to bed or when you go out for more than an hour at a time). This may help prevent expensive damage to other appliances.
Surge protection on your household power (or a surge protected powerboard/strip if that's cheaper and easier to get) is recommended.
Mar 02, 2011 | Panasonic DMR-ES10 DVD Recorder
After a power surge my garage door openers both quit working. The outlets are both getting power. The power surge came from outside the home.
Power surges love logic boards. You should remove the boards and check for burnt or missing traces on the printed circuit. Especially around the small transformer.
Aug 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
Power went out and now the wii won't turn on.
Sounds like you had some sort of power surge. That can kill TVs, consoles and computers. You need surge protector. So possibly the Wii is burnet inside. But only way of telling is to open it. You often can smell if it is burnt.
Jan 09, 2010 | Nintendo Wii Console
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
We HAD A POWER SURGE NOW FRIDGE WILL NOT SWITCH ON
99% chance that the surge blew the power supply board. If it is a French door, bottom freezer model with ice and water through the left hand top door, it may have taken out the motherboard too. Samsung uses at least two boards, one main motherboard and a power supply board that powers the main.
Dec 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Light Bulb Icon Flashing
Unplug it from power.Pull the side cover to check for burnt smell or burnt spots on your board modem or power supply. Unplug the power suppy from the board, unplug the hard drive . Then plug it all up again , put the cover back on it .Plug power cords back up and try it again.If you get no where after this the surge knocked out your power supply or hard drive or board. Always use a good surge protector on all computers and printer and copiers.
Aug 06, 2007 | Compaq Presario S6300NX PC Desktop
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
