Question about Whirlpool Washing Machines
Aw06100p - everytime the washing machine is on the water will go to the drain hose directly..the clothes inside are still dry..in general the machine is not working well
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
  • 489 Answers
SOURCE: heating, draining water(enough?) but not drying clothes, they're just HOT, so is top of machine
You have a problem with the condensing duct.  Possibly clogged with excess and lint and needs to be cleaned out.  This requires disassembly of the unit to get to it.  Not a difficult job but not easy.
Posted on Apr 28, 2008
j_alcaidinho
  • 107 Answers
SOURCE: My washing machine will not spin clothes dry
You need to check ur pump assembly, there might be something blocking it
Posted on Jan 15, 2010
hh0405
  • 77 Answers
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
Posted on Apr 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
What causes a recurrent F21 error?
Hello. The drain error might be caused by something stuck in the large hose coming directly from the tub to the drain pump. Make sure the hose isn't kinked--there is a little pointer that shows the correct position. When you get all the water out, loosen the clamp that holds the hose to the tub and pull it down and away. Check to see if a piece of clothing has gotten jammed inside. Front-load washers are NOTORIOUS for sucking up baby socks, children's undergarments, hosiery of all types, underwires, slips, etc--the list goes on...Purchase several netted clothing bags and put these types of items in it. Wash the bag and DRY THE BAG, TOO! Also, I've seen where the clog is on the *outgoing* side of the pump--the hose that goes to the wall drain. Let me know how it goes. The part number for the tub to pump hose is W10003240 just in case yours is worn or gets damaged. I hope I helped you!
Sep 16, 2015 | Whirlpool Duet WFW9550 Washer
ASKO W620 QUATTRO 1200 RPM front load washing machine. This morning clothes were still very wet, I turned on spin cycle & some water came into machine?? Turned off water at tap - now can't open door to...
Probably a blockage in the drain hose at the back of the machine. Easy to fix. Turn machine off then pull machine out so you can easily access behind. Have bowls and cloths/rags at hand for water spillage. The drain hose is located low down and links into your sink drain, it is held in place by a clip. Remove the clip and hose. This will start to drain the machine so make sure you have enough vessels to catch the water. When the water has stopped draining, check the hose for blockages : buttons / coins / hair grips / paper etc. Also check the hole where the hose attaches to the machine. Remove items then blow through the hose to see if there are any other restrictions. If all clear then replace hose on back of machine. Clear up. Move machine back to normal position. Switch on and set to spin. When complete, the machine should shut off cycle and unlock door. This will save you at least 100 pounds on a call-out. Good luck.
Jun 18, 2014 | Washing Machines
My washing machine keeps all the water inside and my clothes be wet so when i open the door water falls outr
Keep the water draining hose at lower surface than the washing machine. also check for any blockage in the water draining vent and water draining hose.
Oct 29, 2012 | Washing Machines
Water will not drain cannot open door
The possible problems here are blockages or pump failure. Blockages are the more likely explanation but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting (if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from the pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops).
Some washing machines have a filter at the front of the machine that can be checked for blockages. Sometimes the filter is hidden behind a removable trim or panel at the base of the front panel. If your washing machine has a water pump filter and a filter drain hose you should be able to drain the water from the washing machine into a bowl without moving the washing machine. Open the pump filter flap and pull the small drain hose forward. Take the bung out and drain into a bowl. It's likely to be painstakingly slow but at least you don't have to try and pull out a heavy washing machine full of washing and water.
If your washing machine doesn't have a pump filter, or it has a pump filter but no draining hose then it's a bit trickier. To drain the washing machine, you will need to remove the drain hose from the drain pipe at the back of the washing machine, and lower it into a bowl or bucket. Many plumbers now plumb the drain hose into the U bend directly under the sink instead of a separate waste pipe at the back of the washer. If yours is connected directly to the u-bend, you can usually unscrew it easily. Remember though, that with the pipe disconnected from the U bend, any water poured down the sink will flood out into the cupboard until the hose is reconnected.
Once you have drained the water, you need to check for blockages in the pump by unscrewing the pump filter. If none is found, sometimes a blockage can occur in the plastic connector that the drain hose is connected to at the sink end (if connected this way)
Once you have the drain hose disconnected and lowered into a bowl or bucket the water should siphon out as long as the pipe is low enough. You are likely to get several bowls full of water from the washing machine. If little or no water comes out then it may be blocked by an item of clothing like a sock and it won't be possible to empty the machine this way or it is going to be a long process.
Once the last bit of water has drained out, the washing machine may now spin as the safety system for preventing a spin while water is in the machine will now recognize the water has gone and allow a spin. Keep the pipe low down and in the bowl or bucket and put the washing machine on a spin only program. Note, this last step is not strictly necessary as once drained, the door should open. However, you might prefer to try to spin a few more bowls of water out.
Clearly if you put more water into the machine it is likely to fail again until the fault is rectified but these instructions should at least get the clothes out.
Other possible obstructions could be inside the sump hose leading to the water pump. Many Hotpoint washing machines have a filter inside the sump hose which gets blocked. Finally, the pump itself can be faulty.
Dec 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washer does not spin out all of the water & we
The symptoms you have are constant with a clogged drain hose or drain pump.
Try draining as much water from the washer as possible. Then take the drain hose off the machine take it outside and run water through it. If this is clear, tip the machine up and take the drain hose off that is inside and do the same, this drain hose connects directly to the pump in front. When you have the hose off look to see if something is in side the pump like a sock.
Jun 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-H Error
We just had the same problem. We disconnected the water hoses in the back (after turning the water off) and cleaned the sieve. Usually it works again after that. Unfortunately after a couple of washes the problem reoccurs...
Sep 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
