My rca dvd recorder +vcr drc8335b is stuck on hello and wont do anything els.what should I do?
SOURCE: rca DRC 8335 dvd/vcr combo
Call this number 877 805 0519
You need to have the model number (DRC 8335) and the serial number before you call.
Apparently this model has had a lot of problems as they have set up this number specificaly for this model. They will ask you a few questions and then they will send you another unit. You will to pay to ship it yourself. You should read the reviews on Amazon.com.
As for geting your VHS Tape out ...Hopefully when they send you a new machine they can send your tape back with it...but dont count on it.
Posted on Jul 10, 2008
Mike Adams
  • 19 Answers
SOURCE: RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 27, 2008
  • 12 Answers
SOURCE: My DVD Recorder & VCR (DRC8320N) has Hello on display
Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
Posted on Dec 03, 2009
snakehead
  • 1074 Answers
SOURCE: lite on dvd recorder lvw-5045
the point is what was it doing before it start to do what it is doing now.kindly explain then i will be able to help you
Posted on Feb 25, 2007
  • 70 Answers
SOURCE: DVD Recorder keeps getting stuck at "HELLO"
Try going through the menu, and locate update system, do that then when its finished cancel the auto look for updates.
Posted on Jul 28, 2008
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
Nothing Happens but "hello" unless I unplug.
This model seems to have myriad problems and I suspect that it was made in China since the VCR market is fading quickly. If you manage to find warranty info, I'm sure it will require a receipt and probably was only warranted for 90 days as is common with all of our junk consumer stuff these days. The RCA that built that machine isn't the one we remember. I'm sorry for us all-
Dec 30, 2008 | RCA DRC8300N DVD Recorder/VCR
Interface error
(and or)
Nov 13, 2008 | RCA DRC8335
The "H E L L O" message is part of the booting/initialization process of the built-in micro processor of the RCA DVD Recorder. Just like in a PC, it can also suffer from crashes/hangs.
Initially, pls try a reset. "disconnect it from all power and cable sources, leave off for 1/2 hour, then plug back in and hold the stand by buttons for the remote and on the machine at the same time"
If the above is not corrective, then you may have to consider a repair, probable areas to start checking would be:
  • firmware, might need a re-flash or update;
  • hard drive, might have bad sectors or require replacement.
Alternately, if you are not considering a DIY (do-it-yourself), you may have to re-evaluate the options since in some instances, cost and time of repair may no longer justify having the unit serviced.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | RCA DRC8312N DVD Recorder/VCR
Rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
