Question about Pioneer AVH-P5700DVD Car DVD Player
I'm missing the light green wire
Do you know where the wire go's
Hi there could i please have a wiring diagram for a pioneer avh-p6650dvd.thanks have got a manual and its not australian
Posted on Jan 16, 2009
I'm missing the yellow wire and i want to know where do it go
Posted on Jan 13, 2009
Hey, i own a husqvarna sm610 and im trying to remove the stock tail light and blinkers and install a new LED tail tidy strip.
Keep things simple and make this much easier. You will need a test light and probe each of the wires and you will have to do each wire while the lights are on, then the brake applied and then the turn signal and you will be in business in short order. Be shure to make all connections secure and use shrink tubing to waterproof the wires.
Mar 18, 2014 | Cars & Trucks
Emerson Motor model T55CXCAS-1179 230 volt
There should be a wiring diagram sticker on the motor. If not, let me know at questions@oskopoolnspa.com
Jun 03, 2013 | Emerson Pool & Spa
I do not know where the five wires go on my starter for a 1998 Pontiac sunfire
There should be one smaller wire that is purple. That one goes to the smaller terminal on the starter. The rest of the wires go to the larger terminal on the starter.
Apr 05, 2013 | Cars & Trucks
2008 dodge ram speaker polarity
Here is the radio wiring.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jul 14, 2017 | Cars & Trucks
I would like to know how to wire honeywell dt90e thermostat which wires where i have 5 wires from wall
It helps to know which wires went to the terminals on the old thermostat, if it had one. Otherwise, you would really need to know how they are hooked up inside the furnace/air handler. Some technicians hook them up differently, but I can give you the basics and most commonly used wires. R terminal- red/power wire G terminal- green/ fan wire Y terminal- yellow/ cooling or condenser wire W terminal- white/ heating wire C terminal- blue/black/ common or ground wire If you have a rc/rh terminal, they are usually jumpered with a small wire and your power wire still hooks to that. Hope this helps and good luck!
Jun 25, 2011 | Honeywell Heat/Cool Thermostat
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
I have a 274V outlet w/ switch for my garbage disposal. I hooked it up and used a MICRONTA 3-prong circuit tester on the power outlet to make sure it was wired correctly and it showed that the right LED...
you are missing something
you describe 3 led lights --2 green and one unlit then you go on about a red led light
suggest that you get in an accredited electrician to check the circuit
it is possible that you are testing with the wring tester
Mar 27, 2017 | Cooper Wiring Devices 274V-BOX DECORATOR...
I need to know the stereo wiring for a 1998 ford windstar. im trying to put in a new and i dont know what wires to match it up with
here you go...
1998 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1998 Ford Windstar
Pioneer AVH-P5700DVD Car DVD Player Logo
254 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
