Question about Kenmore 63942 Dryer
Thermal fuse failure
I replaced a thermal fuse in a Kenmore Dryer, ran through on cycle and the fuse failed again.
What is causing this failure?
What should I be checking?
  • Eric Bingham
    Eric Bingham Oct 25, 2013
    I went through 4 thermal fuses. I checked the dryer and cleaned out the dryer of all lint, the dryer hose along with the entrance to the dryer vent. My dryer vent pipe is about 16 feet long and goes to the roof. I got a vent cleaning kit with a ten foot extension brush. I got out about four to five feet of lint in the lower part of the vent. I then got up on the roof and removed the vent cover. I cleaned out the vent cover and then with the vent cleaning brush, cleaned out the upper part of the vent pipe. After all the lint was removed, I put everything back together and tried out the dryer. No problems anymore.
  • Kenmore Master
  • 8,220 Answers
That housing where the filter goes needs to be taken out and washed
Posted on Jan 05, 2009
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
My dryer stopped working. I can hear the timer, but it doesn't start
Sounds like a blown thermal fuse problem which is caused by blocked lint duct and vent or a faulty cycling thermostat. The exhaust air temperature rises when there's a blockage in the duct/vent or when the cycling thermostat fails to cycle off properly. The thermal fuse blows when the temperature reaches the fuse rating and terminates power to the motor. The dryer will not start and no dryer function works. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 09, 2011 | Kenmore Dryers
How to change the belt in the kenmore dryer model number 110.62822101. Dryer is not spinning so I would assume its the belt correct?
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
May 29, 2010 | Kenmore 64602 Electric Dryer
Dryer will not start
The temperature of the air being exhausted is monitored by the cycling thermostat and the thermal fuse mounted on the blower housing. The thermal fuse, which is wired in series with the motor circuit, fails when the cycling thermostat fails to regulate the exhaust air temperature. Failure of the thermal fuse results in the motor not running and the dryer not working at all.
Indicate the exact model number of the dryer for specific troubleshooting and repair advice if you need further assistance and for the exact part numbers.
May 27, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore elite, model 110 60952990,stopped working after I tried to dry a pair of sneekers. It doesn't do anything when the power butten is pushed. Thank you.
The thermal fuse (part number 3390719) is blown causing the motor not to run. This thermal fuse is located on the blower housing beside the thermistor (part number 8577274) and it is wired in series with the motor thereby cutting power to the motor when it fails. The failure of the thermal fuse is due the failed thermistor; these requires both the thermal fuse and the thermistor to be replace.
Access to the thermal fuse and the thermistor for replacement or testing requires the removal of the lower front access panel which is secured to the front panel by two retaining clips positioned about three inches away from the sides. Pry the clips to release it and remove the lower front access panel. The thermal fuse and the thermistor can now be accessed.
Using a volt-ohmmeter, check the continuity of the thermal fuse which is to the left of the thermistor. Replace the thermal fuse if it reads open together with the thermistor.
Remove the mounting screws and mount the new parts in place. Disconnect the wires from the old failed parts and connect it to the corresponding component. Reinstall the lower front access panel back into position.
Apr 22, 2010 | Kenmore 63942 Dryer
What will cause the thermal fuse to continually blow.
shorted motor or heating element, which causes excessive current draw would be the cause, replace the heating element first.
Aug 28, 2009 | Kenmore 63942 Dryer
Replaced thermal fuse ,ran cycle all the way than died again.Have had to replace fuse in past would usually get 9 months out of it .Replaced it dryer ran fine but after cycle completed dryer was dead...
Have you cleaned the lint out of the airways and the heat exchanger area? The lint filter traps most of the lint but not all, the airways and especially the area where the heating element is still fills up with lint. To get it out, you'll have to take the back off the dryer and open up the enclosure for the heating element and vacuum it out. The lint clogs the airway, which restricts the airflow, which lets the heating element get too hot, which is why the thermal fuse shuts it off. Otherwise, it would catch fire (and in some cases, still does). It should be good for another few years when you get the lint out. Good luck.
Aug 16, 2009 | Kenmore Dryers
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 63942 Dryer Logo
270 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
