My Magnavox MX931PRO Audio/Video Surround Receiver / Home Audio Theater is not working
SOURCE: LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Posted on Jun 19, 2008
SOURCE: No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Posted on Jul 12, 2008
  • 142 Answers
SOURCE: speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Posted on Dec 11, 2008
  • 4234 Answers
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Dec 17, 2008
SOURCE: Philips FR965/17 Digital Audio/Video Surround Receiver
http://www.p4c.philips.com/files/f/fr965dht/fr965dht_dfu_eng.pdf im pretty resourceful
Posted on Dec 18, 2008
Looking for manual to mx891pro magnavox
http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Dec 18, 2014 | Philips Vintage Mx891p A/v Receiver Home...
Tip
Home Theater / Surround Sound Receiver simple Connection.
Are you tired of trying to remember what input on the Home Theater / Surround Sound Receiver goes with the Input on the TV? Wife fussing at you that the TV is too confusing? Here is a simple way to set up your connections.<br /><br /> <ol> <li>Connect each of your devices ( ie. Cable box, Game Sytem, VCR, ETC) to the inputs on your TV.</li> <li>Locate the AUDIO OUT on the back of the TV.</li> <li>Connect a cable from the AUDIO OUT on the TV to the TV/AUX INPUT on the back of the Home Theater.</li> <li>If the Home Theater has a DVD player built in then connect the Video out (either Component or HDMI or standard Video out) to the TV.</li> <li>When not watching a DVD (if equipped), keep the Home Theater tuned to AUX/TV for the source.</li></ol>The advantage of this set up is that whatever input you tune the TV to will then play through the Home Theater speakers without having to change the source on the Home Theater.<br /><br /><span style="font-weight: bold;"><span style="font-style: italic;">NOTE: Turn the volume all the way down on the TV to avoid distortion due to the slight delay between the TV and Home Theater Audio.<br /><br /></span></span> Hope this tip is helpful for many of you.<br />Robert<br />
on Feb 26, 2011 | Audio Players & Recorders
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
LOST MANUAL HOW O YOU HOOK UP THE SURROUND SOUND TO TV
1. Does your TV has an Audio OUT? If it does then connect the TV audio out to your Home Theater system's Audio In.
2. Are you using Cable box? If you do then connect the Audio out of your Cable box to the Audio In of your Home Theater system. video out of your cable box to the video in of your TV.
Jun 25, 2010 | Philips Magnavox MRD500VR System
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Hooking my flat screen tv to my home theater
Since your output is coaxial (rca) you should be able to find an input for coaxial that will work on your surround the setting on your surround will be either coaxial or digital input,
hope this helps
it would help if you said what kind and model of surround you have
Dec 02, 2008 | Philips Magnavox 42MF521D/37 Television
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
Nice system cheap.
VCR will not play ?
See error message 1 displays.
No error 1 listed in instruction manual nor can I find any in system.
May 18, 2008 | Philips Magnavox MRD500VR System
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
476 people viewed this question
 Grubhead
Grubhead
