Question about Denon Audio Players & Recorders
Compact disc drawer on unit does not open
Drawer seems to be jammed shut - motor goes but does not open- no C.D. in drawer
    Master:
  • 689 Answers
Drawer was jamed,It will have to be taken in to a repair shop, To be realigned, Unless the gears are jaming up, Then you might as well just look for a different one, You could take the cover off to see what it is doing,
Posted on Nov 09, 2012
techman
  • 3130 Answers
SOURCE: The lazer unit won't raise up.
Have you checked to see if the units laser assy is returning to home and when its trying to read a disc, is the lens moving up and down , trying to focus? Have you tryed to clean the laser lens? If you have done all this then your units most likly going to need a laser assy or a servo alighnment. If it has to go into A shop for repair, Im afraid it may not be worth it. GOOD lUCK
Posted on Aug 06, 2006
raverbaby
  • 59 Answers
SOURCE: Cd changer drawer is stuck
GET A SCREW DRIVER ! take the lid off (make sure its not pluged in idiot!) lol!!! anyway take the lid off and take a look inside see if you can figure it out. take a look if you can see any problems jaming the door just explor it remembering where every screw goes you may by doing this may find the problem cheers
Posted on May 19, 2007
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
  • 31 Answers
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
  • 106 Answers
SOURCE: Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Posted on Mar 22, 2009
How can I pry open an unlocked but Jammed file cabinet drawer?
The issue is probably a worn out drawer interlock - that is to prevent you from opening more than one drawer at a time so the unit will not tip over on you.
Remove one drawer and check the mechanism (worn out or bent).
JOAT
May 09, 2014 | Office Equipment & Supplies
Cd drawer came out
Wow , mine did the exact same thing . I don't know how to fix it . How weird is this to even happen. CD drawer just comes out, go figure ?!?!? Did you ever resolve ?
Nov 28, 2013 | Sharp CD-DH950 5-Disc Compact Stereo...
Dd603 bottom drawer locked shut, no displays with power on. How do I get the drawer open?
The thermal fuse that cuts of power to the drawer has been tripped. This means you will need to replace the heater assembly at the base of the drawer. It is not cheap - could set you back by $350-400 to replace.
To open the drawer you need to turn the mains power off and then simply pull the drawer out with a little force. The lid seal is jammed shut because the lid seal actuator motors are locked after the power failed. Do not shut the drawer back as this will damage the lid seal. You will have to call a technician to replace the heater assembly and restore power to the drawer. Hopefully the top drawer is working ok.
Aug 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cambridge Audio AZUR 840C Transport Jamming when disk is loaded
The above comment is complete and utter nonsence !
Here's what you do . Take the lid off , take off the top of the cd transport marked "CD 1 Low Jitter Compact Disc Transport" held on with 2 screws , rince it under warm water (its made of plastic) and refit . Its a build up of dust . Yoy will have to do this every 2-3 years . P.S Leave on "stand-by" because you will do more damage to the circuit boards by cutting the power continually .
Sep 15, 2012 | Cambridge Audio Azur 840C CD Player
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Dvd player seems to be jammed. Is it possible to repair? We haven't tried to repair.
The drawer loading mechanisms are generally not hard to repair, just somewhat delicate. The slot-loading mechanisms are really delicate and fussy. Some drawer mechanisms use a belt drive and the belt sometimes goes bad.
Gear mechanisms usually have a clutch that slips if the mechanism is overloaded. If that is happening, clean out any foreign material (dirt, sawdust, etc.) from the gears and lubricate the gears with a very thin white or silicone grease or if the gears had no grease, use paste wax. Apply lubricant sparingly. You can turn the drawer motor shaft by hand to observe what is happening.
Sometimes the mechanism will jam if the CD gets mis-located on the tray. This is more common on multi-disc units - if the unit is tilted with discs inside, they slide out of their spots and get into all kinds of mischief.
General precautions: do all of your work with the device unplugged. Do not touch the electronics, especially not the optical components. They are vulnerable to static electricity damage, and the optical head focus mechanism is very delicate. And no, you can't protect it with a plastic sheet; the plastic itself will zap the electronics. Just be careful not to touch the optics, period. It usually is not that hard to work around.
Mar 08, 2011 | Onkyo Audio Players & Recorders
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
572 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
