Sony New Xperia S Lt 26i 32gb 4.3 1.5 ghz 12 mp Black Android 2.3 Factory Unlocked Black Logo
sazzyscorpion Posted on Nov 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heating sony xperia
I wasnt using my phone but when I touched it it was hot? what can be the cause of this?
Anthony Tsoi
Level 2:
  • Expert 137 Answers
  • Posted on Nov 04, 2012
 Anthony Tsoi
Expert
Level 2:
Answers
137
Questions
Helped
30846
Points
382
Probably background processes. Sometimes when you keep a game running, it takes up CPU power and hence, may heat up the phone a bit. Also, environmental factors may come in e.g. sunlight.
Xperia t not charging
Check the charges, the charger cable, its connectors and the connector on the phone. Everything should be clean and shiny. Not a speck of dust is allowed in any of the connectors. Use pressured air (in a can) to blow dust or a piece of paper out any contact. Never use sharp or metallic tools to pul out debris.
Perhaps you should also borrow a charger from someone else, to exclude the charger as cause of the problem.
If it is the phone, don't try to repair this yourself, if you don't have the skills.
1helpful
2answers
Why my Sony Ericsson Xperia Arc S is over heating and is draining the battery
my arc s had the same problem when using the internet for long periods. its never caused any problems but if its running really slowcheck which apps you have running and shut down the ones which arent important, and update your operating system to the patest version. my battery used to last round 8 hrs now well over a day. i make sure i only run the apps im using, keep my display brifhtness low and only connect to the internet when using it, this should improve your battery life no end. it will still get hot if your using it for long periods, its no danger but you can place a playing card inside against the battery which will help reduce the heat you actually feel. hope this helps much love CHRISPY
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
I have xperia j.. it needs a hard touch even after updating to jelly bean version 4.1.2
For touch problems you can try to do touch panel calibration:
http://talk.sonymobile.com/t5/Xperia-J/Touch-screen-issue-in-Sony-Xperia-J/td-p/287066
Water damage and the screen is not responding
The phone may still be damp inside. Try using a blow dryer to finish drying up the moisture in your phone.
4helpful
2answers
Touch screen problem
If you're still having touch-screen problems with your Tipo, you might need the screen calibration patch.
Download this file:
http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
The file is the official screen calibration patch from Sony for issues with the touchscreen of the 2012 range phones (I'm 100% sure it works on: Tipo, Tipo Dual, Miro and Xperia J)
Sony mobile phone
Sony Xperia x comes with Android OS, v6.0.1 (Marshmallow), Qualcomm Snapdragon 650 SoC, Quad-core 1.5 GHz Cortex-A53 & Quad-core 1.7 GHz Cortex-A57, Adreno 510 Processor, IPS LCD Capacitive touch screen 16 million colors, multi touch up to 10 fingers with Scratch-resistant glass, Shatter proof glass, Triluminos display, X-Reality Engine, IP58 certified - dust and water proof, Water resistant over 1 meter and 30 Minutes, 5 Inches 1920 x 1280 pixels, 32GB Storage, 3GB RAM ans expendable up to 256 GB via microSD Card, 23 MP, 5520 ? 4041 pixels, autofocus, LED flash, 1/2.3 sensor size, ISO 12,800, geo-tagging, touch focus, face detection, image stabilization, HDR, panorama Back & 13 MP, f/2.0, 22mm, 1/3" sensor size, 1080p, HDR Front camera, Sony Xperia x Performance EDGE, GPRS, GPS, Wi Fi, 3G and 4G Android Smartphone by Sony. Sony Xperia Performance Saudi Arabia Price of Smartphone amp Specifications
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
