DANAHER AC SUPER DRIVER MOTOR CONTROLLER WITH A 5G CODE WHICH IS "No Communications Received from TPA The VM has received no communication from the TPA." I KNOW THAT THE ISSUE IS WITH IN THE TPA, HOW CAN I REPAIR THIS PROBLEM AND IS THERE A SCHEMATIC AVAILABLE?
  • scottdonalds
    scottdonalds Nov 05, 2012
    While looking over the traction power amp I noticed that the capacitors was being read at a plug in point for involving wiring and it should not be there. Apparently the capacitors shorted out the circuit boards. Does anyone know where I can get a schematic brake down of this amp?
4 Suggested Answers
dlundmark
  • 797 Answers
SOURCE: pci simple communication controller driver
Hello fmjos:
Go to the motherboard's maker's site and download all information needed.
You must have the drivers for that mother board, and get them usually from the one who made it.
thanks,
Posted on Sep 02, 2008
  • 6 Answers
SOURCE: 1999 Chrysler 300m ATC Control Communication Failure
i have the same car and it did the same thing when i got it take it to a dealership there are 2 flashes for the bcm body control module that will recalibrate the automatic temp contol and that should fix the problem
Posted on Apr 01, 2009
SOURCE: need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Posted on May 18, 2009
How do I fix error code U0418 for 2011 Ford F-450 super-duty?
Well you better study up on vehicle communication networks . C.A.N - controller area network . How to Diagnose Controller Area Network CAN . Then your going to need factory service repair information . U0418 Ford Invalid Data Received From Brake System Control Module
Dec 11, 2016 | 2011 Ford F-450 Super Duty
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6035
Canon 6035 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controller
I have a 2003 bonniville sle i have a code U1040. Where is the EMCM AND PCM LOCATED
U1040
DTC U1001-U1254 IPC, PCM, SDM
Electronic Brake Control Module (EBCM)
040
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for 5 seconds, a DTC U1??? where ??? is equal to the 3-digit identification number is set.
Control Module
ID Number
Powertrain Control Module (PCM)
016
040
Dash Integration Module (DIM)
064
HVAC Control Module or IPM
065
Rear Integration Module (RIM)
066
Inflatable Restraint Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Head Up Display (HUD)
098
Radio
128
Remote Playback Device - CD Changer
130
Digital Radio Receiver (DRR)
137
Vehicle Communication Interface Module (VCIM)
151
Driver Door Module (DDM)
160
Front Passenger Door Module (FPDM)
161
Left Rear Door Module (LRDM)
162
Right Rear Door Module (RRDM)
163
Memory seat Module (MSM)
166
Driver Door Switch Assembly (DDSA)
170
Remote Control Door Lock Receiver (RCDLR)
176
Theft Deterrent Control Module
192
The electronic brake control module is communicating , no need to bother the PCM . The code was set in pcm because it lost communication with EBCM , PCM not the problem .
Left Front lower corner of the engine compartment, under the air cleaner housing .
Check power's an ground's . Will a scan tool talk to it ?
Oct 03, 2016 | Cars & Trucks
On my 05 Ford mustang v6, my fan only comes on when i turn my AC on and makes a funny noise when I turn the AC on, diagnostic test gave me a code, u1900, what does this mean and how do I fix it?
Where did you pull this code from ? What type scan tool did you use ,or was it a code reader ? Do you know about data communication networks on modern cars ? A U codes indicate a communication problem on the data network .
U1900 CAN Communication Bus Fault-Receive Error Audio Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error ABS Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Instrument Cluster REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error SJB REFER to Section 418-00 . The thing that would make this easier to diagnose would be to have a factory scan tool or a professional grade . Need to know what modules can communicate with scan tool .Honestly ,Don't think you can fix this . Dealer or ASE certified repair shop .Do you know what C.A.N. - controller area network is ? The vehicle has 3 module communications networks:
  • high speed controller area network (CAN)
  • medium speed CAN
  • international standards organization (ISO) 9141 communications network
The diagnostic tool connects to the communications networks through the data link connector (DLC). The DLC allows a diagnostic tool access to diagnose and test the vehicle systems of any module on the communications networks.
All 3 communications networks are connected to the DLC. This makes diagnosis and testing of these systems easier by allowing one diagnostic tool to be able to diagnose and control any module on the 3 communications networks from one common connector. The DLC can be found under the instrument panel between the steering column and the driver door. Which module doesn't communicate with scan tool ?
Symptom Chart Condition Possible Sources Action
  • The anti-lock brake system (ABS) module does not respond to the diagnostic tool
  • Circuit or connection in the high speed controller area network (CAN)
  • ABS module
  • Go To Pinpoint Test A .
  • The audio unit does not respond to the diagnostic tool
  • Circuit or connection in the medium speed controller area network (CAN)
  • Audio unit
  • Go To Pinpoint Test B .
  • Audio unit
  • The instrument cluster does not respond to the diagnostic tool - high speed controller area network (CAN)
  • Circuit or connection in the high speed CAN
  • Instrument cluster
  • Go To Pinpoint Test C .
  • The instrument cluster does not respond to the diagnostic tool - medium speed controller area network (CAN)
  • Circuit or connection in the medium speed CAN
  • Go To Pinpoint Test D .
  • The powertrain control module (PCM) does not respond to the diagnostic tool
  • PCM
  • Go To Pinpoint Test E .
  • The restraint control module (RCM) does not respond to the diagnostic tool
  • Circuit or connection in the international standards organization (ISO) 9141 communications network
  • RCM
  • Go To Pinpoint Test I .
  • The smart junction box (SJB) does not respond to the diagnostic tool
  • SJB
  • Go To Pinpoint Test F .
  • No high speed controller area network (CAN) communication
  • High speed CAN modules
  • Go To Pinpoint Test G .
  • No medium speed controller area network (CAN) communication
  • Medium speed CAN modules
  • Go To Pinpoint Test H .
  • No international standards organization (ISO) 9141 communications network communication
  • Circuit or connection in the ISO 9141 communications network circuit
  • Restraint control module (RCM)
  • No module/network communication - no power to the diagnostic tool
  • Data link connector (DLC) C251
  • Bussed electrical center (BEC) fuse 4 (30A)
  • Smart junction box (SJB) fuse 8 (10A)
  • Circuitry
  • Diagnostic tool
  • Go To Pinpoint Test J .
Apr 11, 2016 | Ford Cars & Trucks
Dishwasher code F4E1
The F4E1 is a code that signifies a WASH MOTOR issue. Specifically, no Communication. This is usually caused by:
A loose connection in Wash Motor Circuit, Motor Communication Circuit and/or an open wash motor.
1. Unplug dishwasher or disconnect power.
2. Check all connections in Wash/Rinse Circuit and Motor Communications Circuit. Fix/replace an open connection/part. Motor fuse on control open.
Using keypad press "Heated Dry", "Normal Wash", Heated Dry", Normal Wash, and the "cancel button" to reset.
Start a cycle and listen for 2 relay contact clicks at the start of interval to confirm both the pilot and motor relays are turning on.
These relays provide power to the motor, but the motor does not start until it receives a start command later in the cycle). If hear only 1 or zero clicks and wash motor does not come on later in service cycle, and there were no loose wire communication wire connection when checked above, then unplug dishwasher or disconnect power and replace control.
Apr 21, 2014 | Dishwashers
DANAHER AC SUPERDRIVE WITH CODE 5G
We have AC Super Drive and its coding 5G what shall we do to fix the problem
Nov 04, 2012 | Watches
Pci simple communications controller
your computer need to install the drivers for modem. because the simple communication controller name is used for the modem
Apr 14, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Wer can i find pci communications controller driver? my board is
Go to Computer Property Click Tab for Device Manager You will find pci communications controller...
Feb 01, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
k24674
jasbo
jasbo
