My lcd tv screen broke i need a replacement screen 46
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not worth doing as the part wholesale is more than a new set.
Posted on Nov 04, 2012
localwonder
  • 6784 Answers
SOURCE: Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
Posted on Feb 18, 2009
  • 105 Answers
SOURCE: I NEED A REPLACEMENT SCREEN
yes.
This requires skill though
If the LCD glass is broken (you see line, stripes, and the watery like drips) it is probably going to be easier to get a new TV.
Anyway, look on ebay for any TV of the same model with a non-functioning backlight, You can use your backlight with the glass from the new TV. You may have broken bulbs so you can swap these to.
OPTION 2. Dissasemble TV to the panel. Find out who makes the panel; it will be LG, Samsung, CMO, AUO, Sharp, something. Find a 32" TV that uses the same manufacturers panel on ebay(this will be difficult but possible with research).
BEWARE.....
1. You must utilize 720P TV panel to replace your 720P panel. 1080P for 1080P and so on
2. LVDS (video signal) will be similar for all TVs except....voltages may be different in case of 32" panel. They will be 6VDC, 9VDC or 12VDC. Also sometimes the cable is reversed from panel to panel. This means that you should be using the original LVDS cable from the Panel you are using the Glass (including the Drive PWB) for.
1 and 2 are kindof technical so sorry if I didn't explain enough. Just know that if you didn't understand it, I suggest doing a lot of research and question asking before trying or you may damage something.
If you are just swapping from 1 TV same model and LCD panel to your TV having being same model or using the same LCD panel...you probably don't have much to worry about.
Good Luck
Posted on Jul 10, 2009
  • 25 Answers
SOURCE: scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Posted on Nov 30, 2009
  • 127 Answers
SOURCE: My 3 yr old hit my 46
If really the screen is damaged (not not just the covering glass), you most probably won't be able to get a new screen. Maybe buying some other TV of the same model... Otherwise only service can order the screen and replace it.. But screens are the most expensive part of LCD TV, so it probably won't be good option.
In any way, get the TV to the service for look and price estimation. Then decide if you want to repair it or buy a new model.
Posted on May 12, 2010
  • 8457 Answers
SOURCE: Need to order a replacement 46" LCD Screen
Sorry,not repairable,because the LCD screen panels are limited produce by the Tvs Corporations.No where u will able to buy a LCD Screen panel for the replament,but except by the tvs corporations themselves.Because it limited production of the LCD screen panels,they will sell it to u the same as a new tv.Might even cost more after the labors of by replacing the LCD screen panel.
Posted on May 23, 2010
Considering buying a used 46'' sharp aquos lcd tv/ mode # LC-46e77u, but the screen is cracked and now needing to know the cost of replacing the screen
Don't buy this tv.The tv LCD screen broken,the tv is junk now,not worth as a whole tv anymore.The replacement of the LCD screen,will cost the same as a new tv.The tv LCD screen panels are limited produced,by the tvs corporation.Will cost the same as a new tv,if require changing the LCD screen panel.
Sep 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
May 23, 2010 | RCA L37WD12 37 in. LCD HDTV
Aquos LC-42D62U 42 in. HDTV LCD Television: 46 inch lcd screen hit with an object and cracked,...
Sorry,no! Because the LCD screen is about 90% of the LCD tv.No where else u will find a LCD screen for sale.Except the tvs corporation themself,LCD screen it limited produce,so the will charge u the LCD screen replacement same as a new tv or even more after the labors and LCD screen replacement.Ur tv now it only can be salvage as for electronics boards for parts that it.Not worth as a whole tv any more.
May 16, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My 3 yr old hit my 46" LCD TV screen with a toy, I think he broke the screen. where can I get a new screen & how hard is it to replace?
May 12, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Can an LCD 46" screen be repaired if their is a crack?
Sorry, any damage to the screen can not be repaired. Replacement screens cost an arm and a leg. The cost would be more than the tv is worth. Basically, it cheaper to replace the TV than fixing it.
Dec 29, 2009 | Sharp LC46SB54U 46 in. LCD TV
We had trama to the screen and broke it. You
Time for a new tv.Panels are usually more than what a new set costs.
Nov 22, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Sreen not broke but the picture inside is when
If you see rainbow colors on the screen, the screen is cracked, you will need the whole panel assembly replaced.
Nov 03, 2009 | Sharp LC46SB54U 46 in. LCD TV
Wiimote hit my 42" lcd can it be fixed?
The LCD panel which is responsible for the picture is toast. You will need to replace it. You can have it repaired using a TV Repair guy but often it costs as much as a brand new LCD.
I recommend just finding the best sale you can and buy a new one.
My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Sep 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Mar 31, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sony Bravia KDL 46XBr2 Screen problem
You have a bad LCD panel. Hopefully it is under warranty still as they are expensive.
Jan 10, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
