Question about Dell 3100cn Laser Printer
I have a delll laser printer 3100cn and I want to print labels and I insert them and it will not print
  • Luan Kruger May 11, 2010
    Are you trying to print from the MFT (Manual Feed Tray) or are
    you trying to feed from the main drawer?
    Rockdude
  • 73 Answers
You need to specify from your computer that you want to print to the MPF tray.
Posted on Aug 23, 2009
SOURCE: Samsung CPL-300 Color Laser Printer Problem W/ Labels
i have a similar problem and whenever i encounter it, i just tone down the contrast of the image then it prints out fine. hope that helps.
Posted on Jun 02, 2008
Corysf62
  • 188 Answers
SOURCE: Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Posted on Sep 28, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
komguy
  • 2306 Answers
SOURCE: HL-5370DW laser printer will not print labels.
It probably wants you to insert label sheet thru the envelope slot in the front, using the cassette peels the labels off of the sheet. If there is nothing in the front slot when you select labels it will show an error.
Posted on Dec 29, 2009
WonderTech
  • 268 Answers
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
Posted on Aug 04, 2010
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer - Not capable of duplex printing? Or yes?
Hi. Duplex printing is optional. You need to purchase additional accessories to enable duplex printing.
Aug 19, 2010 | Dell 3100cn Laser Printer
When I go to print labels, I always get the message to Load MPF paper
I think it wants you to put the blank labels in the multi purp. tray or tray 1
May 13, 2010 | Dell 3100cn Laser Printer
Printer is double printing on sheets for labels, why, what do I do?
Dear change your print settings it is easy and perfect solution. Take a printer properties and then go on paper settings where mentione print copies 2 change with 1 and then save settings, automatically your problem will be solved.
Good Luck
Nov 17, 2009 | Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Dell laser printer doesn't detect paper to print
Dell is sending me a replacement printer, as the help desk couldn't help.
Jan 12, 2009 | Dell 926 All-In-One InkJet Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Setting up for network printing
The best way is to insert the Dell factory Disk into the server and follow the prompts it gives you to set it up on a server as a remote printer.
Mar 14, 2008 | Dell 3100cn Laser Printer
Laser printer problem
For starters aftermarket cartridges are just not like the new ones from Dell. I quit using aftermarket ones long ago to save these headaches, with Dell you can get on Dell Chat and they will gladly help with issues like this. Try that with "Bob's Printer Cartridge and Music Rental" you won't get anywhere.
Mar 13, 2008 | Dell 3100cn Laser Printer
Linux printing with Dell 3100CN
OP provides the solution! (BTW, I'm able to print to this printer from MacOS too.)
May 01, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
