Question about Maytag Washing Machines
Remove tangled apron ties from hoover agitator
rickzilla
  • 706 Answers
SOURCE: drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Posted on Sep 21, 2008
jsrock516
  • 5911 Answers
SOURCE: i have an apron tie strap wrapped underneath the
Different manufacturers have different methods of removing the agitator. Since you posted no brand name or model number of your washer, it makes it hard to determine how your's is configured. The instructions below are for a Whirlpool manufactured washing machine. (This includes Kenmore, Estate and Roper):
1, Remove the agitator center cap (or fabric softener dispenser, if equipped) by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4, Remove the entire agitator by grasping the bottom flange and carefully pulling straight up. Try to keep the upper portion of the agitator (called the auger) and parts assembled while doing this, so do not pull too hard. This will make reassembly much easier.
NOTES:
When reinstalling the agitator bolt, ensure that you DO NOT overtighten. This can damage the agitator and restrict its movement. Tighten until "snug".
When reinstalling the center post cap, make sure it is seated properly. This cap is used as an air gap to keep water out of the transmission. Failure to install correctly, can lead to leaks and potential damage to the drive components.
If your agitator is not one of the models listed above, please post back with your information, so that I may assist you better. I hope this helps you.
Posted on Jul 03, 2009
e-Guru
  • 3917 Answers
SOURCE: how do i remove the agitator to remove a tangled
To remove the agitator you need to unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator if you want and replace the agitator cap.
Note: Damage to the snubbed, a pad like device sometimes located under the agitator cap, can cause the machine to vibrate excessively. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Posted on Dec 06, 2009
  • 35 Answers
SOURCE: apron string caught under the rod the agitator
Is it a top loader if it is.
You can remove the agitator.
Remove the dispenser pops out, you might need a flat screw driver. After that remove the cover in the agitator.
There should be a bolt. remove the bolt and now you can pull out the agitator.
Now you can get the apron string right out.
http://www.pdxappliance.com
Posted on Feb 27, 2010
Daniel S
  • 4323 Answers
SOURCE: the agitator is stuck inn
Hi
Please check this video, seems like something is wrong with the agitator and you have to disassemble it completely:
Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 20, 2011
Hoover 800 rla. Agitator spinning rapidly in one direction and tangling up everything. Been great for 10 years now gone mental. Please advise
In most washers, the reversing mechanism in the transmission broke. You probably will have to replace it.
Sep 04, 2016 | Hoover Washing Machines
How do I wash several aprons together without them getting tangled?
You can tie the apron strings together so they don't get tangled. Or even safer is if you put them in a pillow case and tie a knot in the pillow case.
Good luck
Jul 11, 2013 | Home
Hoover 500M0AUS stops very frequently due to off-balance
Hi there.I'm guessing you changed the (Spin Brake Solenoid) underneath,it attaches to the brake arm,the solenoid retracts with a normal loud clunk & pulls the brake arm away..I think what is happening is the clutch spring inside that white plastic cog is not binding like it's supposed to & it's not taking the drum with it.so the agitator is spinning independantly without the drum.the clutch spring tightens in one direction for spin & loosens in the other direction for wash.either way i think your problem is in that plastic cog & clutch spring,the spring is inside that cog & hard to see.it can be repaired if your up to pulling the entire gearbox out to get to it.I hope this was helpful,it's kind of hard to explain by this method.cheers Chris
May 29, 2010 | Washing Machines
Apron string caught under the rod the agitator sits on. How do I take it off to remove the apron string
Feb 27, 2010 | Washing Machines
Hoover 500M only washes on one direction
The Brake-arm under the washer needs to be replaced it is a white plastic moulded to steel (U) shaped artical connected to an electrical solonoid with a split pin it is either cracked or the nib is broken off where it locates plastic cog on the main shaft assy.Hope this helps.
Dec 13, 2009 | Dryers
I have an apron tie strap wrapped underneath the agitator in the center of the machine. How do I get the agitator off to unwrap it?
NOTES:
Jul 03, 2009 | Washing Machines
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
Hoover washing machine 550mb keep stopping on spin dry cycle.
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Oct 09, 2008 | Hoover Washing Machines
Washing Machines Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
