My samsung top loader washing machine sw65v9w won't stop filling with water
I have a samsung top loader washing machine (model SW65V9W). When I turn the washing machine on the machine fills with water but doesn't stop.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Posted on Nov 04, 2012
  • 46 Answers
SOURCE: Overflowing washing machine
check the pressure switch . its circluar in shape with 6/8 wires attached, and a small nipple with a 10mm pipe attached. as the water rises in the drum air is pushed up thru this pipe which when working ok , eventually pushes against a switch .hence its name. so, if there is damage to this pipe( maybe rubbing against the drum) the passage of air escapes before reaching the switch. if the pipe is ok then check the switch by blowing up the pipe (with the power off ) and u should hear a small click inside the switch. if not replace
Posted on Feb 07, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: Top loader washing machine does not fill up
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
Posted on Nov 10, 2009
  • 273 Answers
SOURCE: washing machine does not stop
The water fill valve (the plastic thing that the hot and cold hoses go to) has an obstruction (piece of rust or minerals from the plumbing) and the valve won't fully close. A speck in the right place is enough to cause overfilling.
or
The water level switch is defective.
or
The tubing that is attached to the level switch is loose or off. This hose must be tight on the fittings.
Posted on Mar 09, 2011
marka19
  • 1430 Answers
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
My washing drained pump burned out. So i replaced it cleande the drum and refitted it all. The problem i have now is my waching machine turnes on and the pump runs as soon as the waching machine is turned...
If you can actually hear the pump running (as in not just hose too low and water draining out), I'd say that the main PCB is shot.
It was probably shot before you replaced the pump (pump burned out from constant running).
These models don't have an overflow as far as I know, unless it is pressure switch based (a possible issue if you did something odd cleaning the drum) remove and reseat pressure switch hose just to be sure.
May 27, 2014 | Washing Machines
Ie error on my samsung sw65v9w
Your drain hose could be to low.
Mar 26, 2014 | LG Washing Machines
Location of the serial number on a Samsung SW65V9W
Check this link for tips to isolate the serial number
click on Washing machine
Jan 15, 2013 | Washing Machines
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
May 20, 2011 | Kenmore 24042 Top Load Washer
My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
May 20, 2011 | Fisher and Paykel Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
831 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
