Question about Sony KDF-50E2000 50" HDTV
Sound went out when lamp is nearing end of life
    Top Expert:
  • Sony Master
  • 14,553 Answers
Sound and the lamp really have nothing to do with each other, not related in any way.
Posted on Nov 05, 2012
  • 4234 Answers
SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: At start up a sign reads, Projection lamp nearing end of life
Might also want to try amazon.com. Sony is 199
Amazon was around 150.
And you can easily do this yourself.
Theres a little door at the right side if your looking at the front. (left if your looking at the rear) Open that up and youll see another door that has a little latch on it. turn it about a 1/4 turn to the left and it will release that door and pull it straight out. then there is the bulb, and that has a little wire ring that is the release. Pull that up and out.
Posted on Apr 01, 2009
  • 1015 Answers
SOURCE: sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Posted on Jan 09, 2010
easyab
  • 132 Answers
SOURCE: Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Posted on Feb 28, 2010
  • 8457 Answers
SOURCE: what does it mean by projection lamp is nearing
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Posted on Mar 17, 2010
T.v. comes on, but 60 seconds later picture & sound goes off for 20 seconds and then comes back on.
Its time for new lamp in tv as existing lamp got weak/ near to end of its working life and causing this problem.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Oct 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen picture constantly goes black then comes back every 3 seconds. Sound stays. Television is 3 years old. Not sure if this is the model.
It is happening because of weak lamp that is near to end of working life.
Replace lamp in tv to fix its issue. Lamp replacement procedure is easy and would be written in user manual copy.
Thanks.
Oct 30, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How does one rid of the "projection lamp is nearing end of life" after an otherwise successful replacement?
Just used the box that came in with the new projection lamp.Take the old projection lamp put it into that box.Put it in the trash recycle bin,that how u get rid of it.
Oct 19, 2010 | Sony KDF-50E2000 50" HDTV
What does it mean by projection lamp is nearing end of life? how can i fix this?
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony projection lamp is nearing end of life
Jan 09, 2010 | Sony KDF46E2000 46" Projection HDTV
Mishb 55
Sounds like the Lamp is nearing the end of its life. Also may be the Lamp Ballast. However more times that not it is just the Lamp. These can be found and online aswell as at most TV Stores.
Oct 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
PD523 lamp icon
sounds stupid, but its not the mute is it? cant check as my acer is in bits at the moment!!!
Aug 10, 2006 | Acer PD523 Multimedia Projector
Sony KDF-50E2000 50" HDTV Logo
12 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
