Coleman furnace running, won't shut off, blowing cold only
Yesterday, we smelled something electrical burning - but couldn't trace it. The furnace was blowing hot air and it was almost 90 in the house. Turned down thermostat. Furnace cooled off, but never quit blowing. It is still only blowing cold air - no matter what I set the thermostat on. The blower won't shut off, unless I shut it off in the fuse box.
  • Lisa Nuhn
    Lisa Nuhn Nov 08, 2012
    I appreciate all the comments that were posted. I had to resort to a professional to solve the problem. Someone had taken the sequensor off before and replaced it with another part - maybe he called it a compasitor? He said the part that was on usually doesn't go bad and that the sequensor does. The compasitor had stuck in and had burnt the top two connectors. He didn't have the compasitor on his truck, but he had a squensor. So he put it on. He also had to change one of the fuses - an old round type. It is now working fine.
    Genius:
  • 1,033 Answers
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Posted on Nov 05, 2012
  • Lisa Nuhn
    Thank you! I tried tapping on everything, but couldn't seem to do anything.
  • 767 Answers
SOURCE: furnace will not blow hot or shut off
The furnace has a fault check the furnace compartment for a flash code and check it with the code chart on the furnace door. Turning the power off to the furnace and turning it back on will reset the fault but it may happen again till you verify the fault and fix it.
Posted on Feb 22, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: i have a coleman in my modular home, dosent blow hot air, everyth
Check the air filter and clean. If you can, raise the blower speed up to the next speed. Make sure all of the supply and return grills are open. Is the ductwork connected under the home and well insulated? Does the furnace ever stop or keep on running? If it does stop, you may have a bad thermostat.
Posted on Jan 03, 2010
mrgrzz
  • 88 Answers
SOURCE: furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
boanhtgclg
  • 34 Answers
SOURCE: furnace will not shut off
something is wrong with the thermostat.  replace it first, that would be the cheapest alternative
Posted on Nov 24, 2008
Electric furnace coleman model # 3120A751. It won't shut off on its own. Just keeps blowing hot air any ideas?
something is wrong in the 24v. make sure no wires touching each other both behind the tstat and on the circuit board in the furnace.
and obviously r to red w to white y to yellow.....
Jan 27, 2015 | Coleman Heating & Cooling
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
Furnace kicks on then shuts off
Coleman furnaces us a temperature delay with a temperature on around 130F to 150F and off around 110F.
If the inrush of cold air cools the delay below the off temperature the fan will go off until the heater heats it up to the on temperature.
Jan 06, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
Jun 21, 2017 | Heating & Cooling
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
My Heater Sparks and shoots out smoke
Most likeley a bad transformer. Shut off the breaker, then remove the cover of the box containing the transformer & circuit board. If the transformer is bad, it will look and smell burnt. Mark the wires before you disconnect it, so you know how to connect the replacement. Then remove the bad transformer and bring it to a heating & AC parts store so they can match up a replacement part for you.
Dec 23, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
816 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
