Question about Belkin (F5D7230-4) Router (587009)
No connection from main computer to another one using router
The other computer say no connection everything is pluged up correctly
  • 192 Answers
Try cheking to see if the eathernet is enabled.
Posted on Jan 04, 2009
Im trying to access the interface for my CT507IT router but the problem is that it hooked up to my WRK54G linksys router that we use for wireless. How do i access the interface for my CT507IT router?
You will need to check the IP address of your CT507IT router.
You said that CT507IT is connected to the WRK 54G router. There are 2 router in your network. First let me know which router is connected to the modem ? WRK or CT507IT . The router which is connected to the modem must be the main router. Connect the computer to that main router and check the IP address of that router. Using the default gateway you can access the page of that router. Now connect the computer to the CT507IT and check the IP address and default gateway. use the default gateway number to open the page of CT507IT.
Everything depends on the connections of your network.
Please clarify the connections.
Apr 15, 2010 | Comtrend CT-507 Router
Tip
How to set up router
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for step bi step instructions
on Dec 03, 2009 | Computers & Internet
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
Slow dsl
The cable modem should be connected to the WAN port of the router. Then the computers should be connected to any ports from 1-4 at the back of the router.
Once they are connected properly. Reset the router. Just hold the reset button for 10 seconds. Then turn off the modem, router and all computers.
Then you need to turn on the modem first, wait for the lights to become solid green, then turn on the router. Once the WAN light on the router is on, turn on the computers and check if there is internet connection.
If still no internet connection, contact your ISP. They might need to clone the mac address of router to their end.
Hope this helps! Good luck!
Feb 08, 2010 | Linksys EtherFast Cable/DSL Router
No internet connection
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
My d-link wireless router lights turn on properly but it is not sending any signal and when connected by lan the computer says limited connectivity
Try resetting your broadband connection, then the router, then your computer in that order.
These devices get out of sync on their addressing occasionally and a front to back reboot is all they need.
Dec 09, 2009 | D-Link DIR-615 Wireless Router
Can connect to router, but not to internet
Is the main computer connected to the router or to the internet directly? If it is a cable modem for the internet, make sure you turn that off, as well as the router, and connect the cable modem to WAN on the router and put the modem on first, then the router. Connect the computers, xbox, etc to the router
Jun 06, 2009 | Microsoft Broadband Networking MN-500...
Laptop connecting but not my desktop
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Can't go online from Main Compter after Installation
Does your router tell you it has an internet connection? (you can check this from the routers status page on it's web interface). If not, unplug the router and modem, then plug in the modem (wait approx 10 seconds). Once the modems status lights are static, plug in the router, and check the internet connection.
May 23, 2008 | Belkin (F5D7230-4) Router (587009)
I cannot detect my router
A first logical step would be to take your laptop to another wireless location and see if it will work there (you could also take the your wireless unit there to test it). Likewise invite a friend with a wireless enabled machine to visit you and see if they can see your wireless unit. There are three different types of wireless devices in common use A, B, G you need to know which your machine uses and which the wireless receiver uses and assure there is a match. Some devices support multiple types A&G, B&G and A&B&G as long as one matches between the wireless adapter and wireless router/access point assuming the others were not configured off the test should be valid.
Dec 07, 2007 | ASUS (wl500g) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
