Question about Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner
Trying to use pctv hd pro stick Msg: PMc loader.exe stoppe workin
Also cannot create programs. please install .net framework 2.0 Where is .net framework 2.0?
  • 64bryan Jan 14, 2009
    Have installed net framework.2.0 three times but to no avail
    now running nero 7.9.which has scanned all channels (23) but cannot produce a picture due to pmc loader.exe not being installed
    Running xp windows on acer laptop
    Any ideas?? Thanks
    Bryan 64bryan@gmail.com
0345-3548288
Posted on Jan 06, 2009
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
I lost my installation cd
ftp://ftp.pctvsystems.com/TV/driver/PCTV%20340e%20801e/PCTV%20340e%20801e.zip
ftp://ftp.pctvsystems.com/TV/driver/PCTV%2070e%2080e%20100e%20320e%20330e%20800e/PCTV%2070e%2080e%20100e%20320e%20330e%20800e%20880e.zip
download both of these drivers there are the only pro sticks that pinnacle has but i dont know which one you have
http://www.pctvsystems.com/LinkClick.aspx?link=145&tabid=124&
this is the program it runs in
Oct 21, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
Vista HOme Pro 32 bit and USB PCTV HD Stick
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/PCTV+Tuners/PCTV+Analog+PVR+(cable_antenna)/PCTV+Pro+USB+Support/Download+Area/Drivers+-+Updates/TVC498_800i_800e_801e_150e.htm?mode=documents&Display=1
here is the web page for the drivers and solution under support
Jan 17, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Pinnacle PCTV pro stick 801e
Hi Adam,
Here is the link for tv center pro for your vista 64 bit download and install this to your computer. http://cdnexpress.pinnaclesys.com/akdlm/SupportFiles/TVCenter/TVC540/PinnacleTVCenterProSetup_5.4.0.3032.exe.
I suggest also to connect your tuner device at any usb port.
By the way you need the serial number for the new tv center pro.
Enjoy.
Dec 11, 2008 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Pro stick software problem
go to the program file folder and delete the folder then go to add/remove and then remove, it will see that the folder and uninstall.exe is missing and will remove it, then you will be able to reinstall
Dec 05, 2008 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner Logo
2,204 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
