Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
How do i remove the ice shoot on my ge profile model# pfss6pkw
  • J vieria Nov 04, 2012
    Sorry, i didnt explain this well enough...the part that is broken is the lever that you would put your glass against and push to get ice. I need to know how to remove the broken part and replace it. how do i remove the control panel as well
  • daniel  hendrickson
    daniel hendrickson Nov 07, 2012
    Pop the control panel off by taking a thin blade knife at the bottom of this panel and prying out on the two edged of it,then unplug the wire harnesses to it,then remove 4 phillips screws behind it remove the paddle assembly,dont lose the little spring on the paddle
    President:
  • GE Master
  • 1,922 Answers
Posted on Nov 05, 2012
3 Suggested Answers
SOURCE: GE PFSS6PKW display shows "88" on freezer side and
I am having the same problem after the power was turned off and then reconnected. Have you had any luck finding the source of the problem?
Posted on Nov 20, 2010
SOURCE: How to remove front panel from ge ice maker model PSS26SGPASS
If you are talking about the ice/water dispenser palnel, on my PSF26NGPABB Arctica it just pulled off. there is double sided tape all the way around it and I used a thin, sharp knife to cut it as I pulled the panel off.
Posted on Dec 28, 2010
How to reset Panel for PFSS6PKW bottom freezer GE Profile Refrigerator? When power went off display is just showing 88 88.
Try pressing and holding the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 or 15 seconds. It should give you and audible beep and reset the panel.
Oct 16, 2014 | Refrigerators
Ice maker freezes up
Replace temp sensor in freezer and main control board
Nov 06, 2013 | GE Refrigerators
GEProfile model #PFSS6PKW icemaker knocking
There are no serviceable parts on that ice maker and it will need to be replaced if you find it to irritating. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile refrigerator that will not dispense water or ice. The panel and light work and when you try to get ice or water it does nothing. No noise either. It is model # PFSS6PKW
When both ice and water do not work it is usually related to the door / light switch failing. Check the door switch by depressing the plunger and see if the compartment light goes out. If it oes not go out the switch has failed. WITH POWER REMOVED the switch is removed by using a thin knife blade to release the single locking tab on one side of the switch. The switch had 3 terminals
C = Common
NC= Light
NO= water and ice.
You should read continiuty (resistance)
from C to NC plunger extended
from C to NO plunger depressed.
If this switch is good then there is a problem with door hinge wiring or control panel wiring.
My bet the door switch has failed.
There are 12 models of this french door refrigerator.
The door switch it item 636 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227912&diagram_id=26230325#d26230325
Detailed views:
http://www.appliancepartspros.com/Appliance-Parts/ge-switch-light-ff-item-number-ap3796657.aspx
Thanks for choosing FixYa,
Kelly
Jul 12, 2011 | Refrigerators
We have a GE profile side by side refrigerator with the freezer on the bottom (model PFSS6PKW). It's not quite 4 years old yet, but we've been having issues with low water pressure from the water...
you may have a restriction in the water line ( after the valve and it may be in the water storage tank .. it may be ice and it will block the line some what . to slow the flow .. if not ice it may be sediment / these are the most common found .. .. i would clean the lines or replace them .. . if pressure is ok at the main inlet line .. ..mm hope this helps mm
Jul 11, 2011 | GE Refrigerators
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
206 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
