Question about Electrical Supplies
Wont start shoots fire out of carb, already checked keyway, checked timing inside, what am i missing? any help is very appreciated.
  • 211 Answers
Hi
Check the spark at the sparkplug,compression (piston rings,intake and exhaust valve clearance,cilinder gasket)and carburator"s adjustment.Happy new year!
best regards savumihai71
Posted on Jan 05, 2009
Cranks and fires but wont strats
Hi Anonymous, sounds like you have a fuel pronlem. Check fuel flow to carb, check fuel filter remove air cleaner and squirt starter fluid or Brake Kleen into carb throat, if it fires up and runs for a few seconds then you have a carb problem. Remove carb and bowl clean clogged jets and air passages, and clean bowl. Visit website below to download cheap ( $5.50 ) service manual that will walk you through it and also trouble shoot:
Harley Davidson Manuals Mark Workshop
Good luck
Apr 04, 2014 | 1979 Harley Davidson XLS 1000
Engine sincronize time
the timing is not adjustable
the rotor rest on a keyway on the crankshaft.
the pick-up(signal generator) rest outside the rotor.
the pick-up send the signal to the CDI
the CDI send the signal to the corresponding coil pack.
which fires 1&4 cylinder coil pack, then 2&3 cylinder coil pack.
theres nothing to sync.
Now if your refering to your carbuetors, you can sync those.
On the bench:
Basically sync the carbs so the butterflys all open and close at the same time. turn the idle srew in so butterflys will start to open and you can see daylight through them.
measure thebutterfly opening height in each carb,if all the same its synced
if they are different, turn the adjusting screws slowly and in small increments to achieve the same measurements.
On the Bike
must have a vaccuum gauges also called manometers.
hook up the manometers to your carbs and run at 1500-2000 rpm
adjust the carb butterfly ajustment screws in small increments while watching the manometers vacuum gauges, adjust untill all the same level
should be somewhere between 14 - 18 cmHg
sometime the outside carbs run different then the inside carbs
if they do, adjust the outside carbs equal and inside carbs equal.
Hope this helps you out.
Best Regards
Big Al
Aug 02, 2012 | Yamaha Motorcycles
Echo pb251 blower wont start
remove the muffler and try it carbon plugs up the screen inside if runs good with out the muffler open the muffler and clean the screen
Jun 18, 2012 | Troy-Bilt Garden
Konked out still cranks wont fire 99 pulsar 1.6 auto replaced pump
Always check for the basics before replacing stuff to avoid time wasted and costs.
Check for spark at plugs while cranking,use a plug with a gap stretched out wide to work coil and module.It should be a healthy crack when it sparks.
Check for lack of fuel by spraying a carb or brake cleaner into open aircleaner while engine is being cranked.If it starts you will need to test fuel pump and power to it.
Check compression,nil or very low indicates broken timing chain/belt/keyway or internal damage.
I hope this helps,let me know your findings and we can work towards a fix.
Apr 01, 2011 | 1990 Nissan Pulsar
Hi 2000 yamaha Vmax, 4600 miles on the clock.
This sounds like a carburetor problem. Either bad gas, partially plugged pilot jets, carb diaphragm cracked or has a pin hole, carbs out of sync or diaphragm cap is not tight. It would be best to have a dealer check it out. However, before going to the dealer I would try one thing. Drain the float bowls on all four carbs. There is a drain plug on the bottom of each bowl. Condensation inside the gas tank can make it's way into the carb. Bikes don't run well with water in the gas. Please rate my solution. Thanks.
Aug 12, 2010 | 2000 Yamaha V-Max
Having trouble to get it running it fires but wont run i have new plugs and cleaned the carbi and fuel on a bolons st 120 1990 modle ridermower
choked? bad gas. gas sitting for only a few months will go bad. Spray some WD40 into carb and try to fire. if it runs replace gas. Check to be sure keyway has not slipped
Mar 05, 2010 | Garden
My 5700 runs about 5 min. then back fire out the carb and then wont start for about 10 min. then it starts and run about 5 min. and stop agin i clean the carb check the valves
I would first said that your intake valve is not sealing like it should (burned, warped, etc). But, you have already checked that.
The other reason for a backfire is timing. Could your magneto or keyway be heating up and moving throwing off the timing? And speaking of keyways, how does the woodruff key look? Is it chewed up or distorted?
Nov 10, 2009 | McCulloch Electrical Supplies
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Electrical Supplies Logo
110 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
