Question about LG WM-3677HW Front Load Washer / Dryer
LG drier will not dry
Will not dry shuts down
    Top Expert:
  • LG Master
  • 9,472 Answers
Check the heating element for continuity. Here is the part if you find it bad.
Posted on Nov 04, 2012
Lg gas dryer something burning
burning smells in driers can be sometimes from a blocked lint filter. The dried lint has been known to ignite when it gets hot. If you haven't cleaned the lint filter then do so and if the smell continues get it serviced.
Nov 20, 2014 | LG Washing Machines
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
DRYER TAKES 2 CYCLES TO DRY. WHAT CAN BE THE PROBLEM
Check to make sure lint hasn't built up in the area of the lint trap and on the exhaust where it leaves the room. Improper air flow will cause the drier to over heat and shut down the elements to prevent a fire. Once the elemnts are cool then they start again until they reach that temp. again then they shut off. So check for lint buildup before anything else
Hope this helped
Dave
Mar 03, 2010 | Dryers
I have a whirlpool duet. The burner stops after about 15 sec and clothes don't dry
Two things can cause this one is the vent hose and or the vent going out side. If it (the hose or the vent) is stopped up this will happen. Also The Drier has a protection switch mounted in the burner area. This switch is going bad. It is there to shut down the drier in case of a problem it is kicking in/out too soon most likely it is going bad. When it shuts off, open the door let things cool off for a minute see if it will restart.
Jul 30, 2009 | Whirlpool Dryers
Drier keeps shutting down.
I had the same problem, they wear out in the rear bearing slot and drag on the front slides, So I bought Sears heavy duty model and it was was running better than ever until my wife took it away when she left me. Hope this helps
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
MINE BLINKS HE
you got a vent restriction look behind your drier with a flash light and see if vents too long or mashed go outside when drying clothes see how much air flows comming out best way to do vent is 4in pvc drain pipe from hood out side to floor then 90dgree elbow up through floor short peice of pipe then foil drier vent from back to pipe with clamps your air flows blocked backing heat up in drier
Nov 12, 2007 | LG DLE2532W Electric Dryer
LG WM-3677HW Front Load Washer / Dryer Logo
115 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
