Question about HP 1240 Plain Paper Inkjet Fax
Using 5 port stealth box to share phone line between pc and fax
I connected a 5 port stealth box between a fax and pc internal modem. The fax is plugged into one side of a splitter on the main line and the stealth box on the other 8 conductor side. if a ,2,2,2 in the modem dial string is used to go to the pc it works fine. if a fax calls in, the line is busy to the incoming call. i called the fax line from my cell phone and it actually went to the fax and the fax tried to receive. Why will my cell get directed to the fax, but not another fax machine? Please help.
3 Suggested Answers
  • 167 Answers
SOURCE: machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Posted on Sep 26, 2007
leroyal
  • 2120 Answers
SOURCE: NOT RECEIVING FAXES OR INCOMING CALLS
Unplug for 10 seconds. Set to AUTO ANSWER
Posted on Oct 09, 2008
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Need manual for connecting fax to phone line and computer
Simple:
* one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
* one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
Connection a Netbook to dial up
You would have to purchase a usb modem, similar to:
  • 71535167228793271903075993308225889520.jpg http://www.avondalesystems.com/images/products/93942447.jpg zoom
  • Fax Modem Usr5637 56k Usb The USRobotics 56K USB Modem delivers the performance and reliability USRobotics is known for, in a compact,…
  • Mar 18, 2009 | Dell Dimension 4300S (Refurbished)...
    How to connect the telephone lines
    Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
    i.e is fax line ) or the usb port in the computer ...
    Good luck...
    Feb 02, 2009 | RCA 25201RE1 Corded Phone
    Can't print from PC when a phone is in use on same line
    hi i think its some short circit to ur fax boart to or telephone line. beter u check ur telephone line and fax modem card.
    Jul 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
    Setup computer w/ faxing
    Yes you can. You need a fax modem which you can get either one of the following:-
    1) external fax modem which plugs in to the serial port of your pc
    2) an internal pci which sits on one of the ports on the systemboard which is easy to install.
    May 03, 2008 | HP Officejet 7210 All-In-One InkJet...
    HP 1240 Plain Paper Inkjet Fax Logo
    69 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
