Question about Dell OptiPlex GX280 PC Desktop
Lan Shutdown problem
Hello there sir
Im on a LAN and i need help so i can shutdown my friends computer.
Im connected to a Box with cable and i tried to use the shutdown -i in command prompt but did not work.
Pleas i need help :)
  • tnmatt May 11, 2010
    Please provide more info. Box with a cable? Cable modem? Router? Are you attached to a home network? Operating system?
  • 139 Answers
Go to website and install and download logmein your can have 1000 computer connection at one go even if your are in some other country you can shutdown remotely access as many computers as your want
Posted on Jan 13, 2009
  • Chetan Gupta Jan 13, 2009
Wake on lan not working
I'm not sure what is your problem the WOL or no connection icon after sleep
Jan 09, 2014 | ASUSTeK COMPUTER Asus M5a99fx Pro R2.0 -...
Lan port shutdown automatically
I would suggest resetting to default settings and hit the F 10 key to save and exit.
Oct 21, 2013 | Asrock Computers & Internet
Im trying to connect my modam could you please help
First step is to make sure if the modem is functional. This can be done by connecting your computer to modem and check if you are able to log on to internet.
Second step is to connect the cable which previously connected to computer to Router's WAN port not LAN
Third step is to power cycle the modem and router that is power off and on both modem and router
Last step is connect router to your computer with new ethernet cable using one of the LAN ports of the router. There are usually three or four LAN ports on Router!
Good luck! Repost if you still need help!
Sep 06, 2011 | Computers & Internet
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
HP ML350 G5 can't auto bootup after shutdown
It's divide and conquer time! First let's see if it's UPS or server related.
Try any, or all, of these Wake-On-LAN utilties to see if the server responds:
http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx
http://www.matcode.com/wol.htm
http://www.solarwinds.com/products/freetools/wake_on_lan.aspx
If it does, then there is a problem with the UPS that needs further invesigation.
If it does not, read this article from APC:
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=eIzqf7Ti&p_accessibility=0&p_lva=215&p_li=&p_faqid=2929&p_created=1057853424&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OCZwX3Byb2RzPTQ1MSZwX2NhdHM9JnBfcHY9MS40NTEmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13YWtlIG9uIGxhbg**&p_search_text=wake+on+lan
Also, if you are using a switch/router to connect the UPS to the LAN, make sure your network devices are configured to allow WOL.
Jun 19, 2009 | HP Compaq ProLiant ML350 G5 Server
Sir i we are 2 friend connected with LAN hub we want to connect via LAN. i want LAN setup between us
yes for this you both have to set workgroup name same .first connect the LAN cable to lan ports of yours...then in Network setting give manual ip addreess as 192.168.1.1 in one computer and in other as 192.168.1.2 (subnet mask would be same) .then u bath can access each other computer by sharing folder....
but you have to disbale windows firewalll
Dec 09, 2008 | Microsoft Windows XP Professional With...
Dell Inspiron 1525 with Vista
I'm out for the evening, but I'll be back tomorrow morning. Leave the info and I'll get you a solution.
Jun 20, 2008 | Computers & Internet
CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 24, 2008 | Cnet (CWR-854) Wireless Router (cwr854)
Totally cannot run!
have you got your lan card drivers installed and is the windows firewall blocking connection as this can cause problems also check that the device is not being shutdown in windows newtork manager, if problem persists then get a converter to change lan to usb and install drivers for camera. good luck on connection.
Oct 03, 2006 | Axis Communications 2100 Network Camera
Onboard Lan causes boot and shut down problem
It sounds like you have some bad LAN circuity on your motherboard. You might try a workaround by installing a separate LAN card and using that. If the separate card doesn't solve the problem your motherboard is just bad and needs to be replaced.
Aug 19, 2006 | Abit AA8-DURAMAX Motherboard
Dell OptiPlex GX280 PC Desktop Logo
79 people viewed this question
Alun Cox
