Question about Lexmark X3650 Printer
My lexmark x3650 will not communicate with my computer. help?
Installed cd. checked various usb ports. went through troubleshooting steps. tried another computer. installed driver.. still says no communication between devices. Which confuses me because when i insert an sd card directly into printer, the images come up on computer.
I can copy. But i can't print.
  • 1 more comment
  • jl218 Jan 05, 2009
    Followed every setup step to the letter, but when I get to the final step of printing off a sample page, it says Communication Not Available - the printer and computer cannot communicate.
  • scrapedupent Mar 31, 2009
    I still got the samemy lexmark x3650 will not print. error message printer cannot communicate with computer message. thanx though
  • joecu Apr 09, 2009
    followed all the steps. no communication available message. please help
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Troubleshoot scan for an x3650? I am using an ASUS laptop with windows 7. Desperately tying to scan and send payroll. It's worked previously, but not now.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
It says it can't communicate with the computer
Remove all the cables which are connect to printer
Press the power button for 10 to 15 sec -
Connect cables back - check whether computer prompts the connection info. If not change the usb connection.
Check the test print.
Final step is reinstall the software drivers.
Nov 03, 2010 | Lexmark X3650 Printer
Printer cannot communicate with printercommunicate
I would suggest:
Go to Printers and Faxes and delete your printer icon
Disconnect your printer's cable (connected to your PC)
Restart your PC
Reconnect the printer's cable
Your PC should see the printer and install the printer's driver software.
Hope this helps.
Sep 08, 2009 | Lexmark X3650 Printer
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
I have a Dell computer that i just recently puchased. I went to wal-mart and got a Lexmark z1300. It came with the cd that i up loaded and had no problems doing. It shows that the printer is active and...
try this...go to printer and faxes....right click on the printer which is ur default printer (Lexmark z1300) ...now go to its properties....in that click on ports tab...see that weather it is using usb port or not...hope this will workout..:-)
Apr 02, 2008 | Office Equipment & Supplies
1st -make sure that the USB cable is connected on the correct port of your printer - you might be plugging it on the ports of the telephone - you got 3 ports there - 2 for the telephone ports and 1 for the USB
2nd- check your service if print spooler and lx devices are started (lexbce or lxdcu) - if not.... start it
>start >run>type services.msc > enter
3rd- if still no go - uninstall your driver and download windows vista x64 printer driver on their website
Jan 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X3650 Printer Logo
277 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
