Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway fpd 1960 goes black intermittently
Monitor goes black intermittently, power is on, does same thing on 2 other cpus, used different cable, same result sometimes and hr or 2 no issues can always power down monitor and power up immediatly and it works for a few mins or a few hrs... no time table but same result eventually, on average about 8 to 10 per hr. any help?
  • Simba77 Feb 03, 2009
    I have the same problem and it is DEFINITELY the inverter.
    I tore apart the PSU and seen most of the SAMXON Capacitors bulging or have popped the bottom cap.
    This could be an easy (and cheap) fix. Just head to your local electronics store with the inverter board and ask for them.
    Some, with a few bucks, will replace them for you. Make sure you use well renown capacitors (ex. Rubycon).
Some, with a few bucks, will replace the capacitors for you. Make sure they use Rubycon (or some well known) capacitors.
Posted on Feb 03, 2009
    Sergeant:
  • 226 Answers
Your inverter is dying. It produces ~2k volts for the ccfl (cold cathode fluorescent lights) that surround your display. At a few milliamps. Probably bad or leaking capacitors on the inverter or power supply board. So it is either using too much power (bad ccfl) or a weakening power supply (higher likely).
It could be cold solder connections becoming intermittent. Remove the base, remove the screws on the backside, and split the case CAREFULLY. Inspect the power supply and inverter for obvious failure or leaking capacitors. Replace same... If your lucky, it will work.
tom
Posted on Jan 04, 2009
How to open gateway FPD 1765 LCD CASE OR BACK COVER
At Last! Okay this is how you open a Gateway FPD 1765 monitor. This Monitor open from the front first to reveal 4 screw under the black trim. Lay the screen face up, NOT FACE Down. So that the GATEWAY LOGO is looking at you. Carefully, lift up the black plastic trim slide a knife or slim tool, or your fingers will do,lifting the trim up a off. BE CAREFUL NOT TO BREAK THE POWER BUTTON WIRES, near the power on button. Then remove the 4 screw holding the back cover on. When you remove these screw the monitor is free, but careful there are 2 set of thin short wires that need to be un plug. You should be able to go for there.
Jan 30, 2011 | Gateway FPD1765 17" Flat Panel LCD Monitor
When turned on, monitor (LCD)shows desktop for +/-1-2 sec. and goes black
Have you tried this monitor on a different computer? If it happens on a different computer then most likely the monitor is defective.
Nov 19, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor flashes on but with 1-3 seconds it goes to balck screen. I've replaced the electrolytic caps in the power supply, but it didn't help
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Mar 10, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1960-uk 19 " LCD?TFT Monitor keeps going into standby
It sounds like the monitor whose writing comes up in pink has a problem with the RGB usually IC driven and all of them sound like they have faulty power supply boards. Will investigate further and give a more detailed answer. Hope this helps for the time being.
Oct 11, 2007 | Gateway 19" Flat Panel LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
190 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
