Question about Garden
Yazoo/Kees mower key in ignition won't turn - Garden
3 Suggested Answers
  • 59 Answers
SOURCE: briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Posted on Jun 27, 2009
  • 539 Answers
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
Try http://www.manualowl.com
Posted on Apr 13, 2012
Troy Bilt GTX 18 lawn mower engine won't continue running
ck. to make sure the wire to the ignition coil is hot. may need to replace the ignition switch.
May 24, 2013 | Garden
Try starting my 19.5 hp craftsmanriding mower and no click and cross over the solnoid and it turns over but no start
If it is equipped with a seat safety switch it won't start unless someone is on the seat or the switch is bypassed (which you shouldn't do for safety concerns). You could also have a bad ignition switch which is not uncommon.
May 18, 2012 | Craftsman Garden
When installing key in my b/d rechargable mower don't go in easy & won't start
IGNITION COIL BAD PULL WIRES OFF BACK AND HOTWIRE OR REPLACE IGNITION
May 09, 2012 | Garden
Ordered new mtr to repl B & S 6hp rated mtr on Yazoo Mfg Commercial Mower. The mower is not at ths site, so I can't give you the mod of new mtr, but it was a 9hp rated mtr w/controls on opposite...
In Briggs & Stratton motors used in mowers or similar equipment the spark is generated by a magneto : a magnet situated on the flywheel passes in front of the ignition coil and generates the spark.
If the engine is backfiring then the flywheel is incorrectly positioned - take it our and rotate it for one bolt
Aug 08, 2011 | 1992 Honda Accord
My dls 3500 mower will not start at all, I charged the battery but the engine wont even turn. All the wiring and fuses seem to be ok
I had the same problem. I replaced the wiring harness for a short fix, corrosion in the terminals that connect to ignition switch. This worked for a while. Then replaced ignition switch this also worked for short time. Now I just open the hood to reach behind the ignition switch and wiggle wires while turning key to start until it starts keep wiggling to get good contact. If it won't stop after it starts, wiggle wires after you turn the key to off. It will stop.
May 29, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs & stratton 18 HP intek ohv won't start
Jun 25, 2009 | Garden
Yazoo rider left side pump stalls when cold
Im not a yazoo dealer but I can tell you some easy things to check, If you have a reservoir tank with an oil filter in line, there are two kinds of hoses suction and return if there is an air leak on a suction line it may not show an oil leak but it will put air into the pump making it week most of the time its cheap
hose clamps or loose hydro filter .
A lot of hydro use a gear case bolted right to the pump without any hoses , but that not what we call commercial .
good luck
Feb 16, 2009 | Craftsman 10.5 Hp 33" Commercial Cutting...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
