Question about Microwave Ovens
NN-A574SBBTQ PANASONIC INVERTER SLIMLINE COMBI MICROWAVE OVEN
I need the manual
MicrowaveSvc
  • 9098 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I desparatly need instruction for the NN-A554W
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Posted on Mar 06, 2009
SOURCE: need a manual for a panasonic inverter combi
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Posted on Aug 20, 2009
jsrock516
  • 5911 Answers
SOURCE: our neighbour is misson the user manual for her
Go to managemylife.com and type in your MODEL NUMBER under the "Manuals" link. The website has an extensive list of owner's and installation manuals for many brand names. The manuals are listed in .pdf (Adobe) format and can be downloaded or printed for FREE. If you need further assistance, please post back with your MODEL NUMBER and let me know.
Posted on Jun 07, 2010
  • 6771 Answers
SOURCE: Panasonic inverter microwave model NN-A574SBBTQ
If everything else is running, it means the turntable motor has become defective and will need to be replaced, this is a common problem with many brands.
Posted on May 15, 2011
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Panasonic inverter microwave model NN-A574SBBTQ . The turntable has stopped working. Any ideas please.
May 15, 2011 | Microwave Ovens
I have been given a Panasonic combi inverter microwave/oven. There are no user instructions can you help me to find a manual?
here is the link to the instruction manual of your device from panasonic:--
click the link directly:--
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/model.NN-H275BF
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 06, 2009 | Panasonic Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
Mar 05, 2009 | Panasonic NN-A811A Convection/Microwave...
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
The bulb is not working in my Panasonic NN-A554W inverter slimline combi oven and I do not know the size/number to obtain a replacement. I know you are supposed to get in an engineer but that is a bit...
It's a T170 type bulb (should be very common at a grocery store or hardware store) rated at 240 volt, either 20 or 25 watt is okay, and if you order it as a spare online, it may come with the 90-degree bracket.
You can see a good photo and detailed specifications here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
104 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
