FixYa.com
Tags:
Hansol Multitech 920p  19 in.CRT Conventional Monitor
Screen Whine (by 2 users)
posted by dougzy on May 20, 2007
There is a constant high pitched whine being given off from the Hansol 920P monitor which has just started recently and I was wondering if it is a fixable problem?
Comment by dougzy, posted on Jul 13, 2007
Thank you for your help. The monitor seems to be unable to support 1280 by 960 but I increased it to 1280 by 1024 and the problem is solved. Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by valsys, posted on Feb 29, 2008
i have a samsung 753s which gives out a loud whine when it goes into standby
Best Solution
posted on May 20, 2007
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 86%, 1984 votes
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Sony CPD E200 Monitor HP vs19 (Silver) 19" LCD Monitor Philips 107E61 (White) 17" CRT Monitor Philips 170B4MG 17" LCD Monitor Philips 170B5CB (Black) 17" LCD Monitor Philips 170C4FS (Silver) 17" LCD Monitor Philips 202P40 22" CRT Monitor
Can you Help with these Monitors problems?
Monitors
22" flatron (W2252TQ)...
I have two problems. I was... Answer This...
Monitors
broken pins in monitor cable
I broke off a pin by accident... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
