Question about McCulloch Garden
Manual for McCulloch chainsaw M3414
How to sharpen chain using the part provided
rwvanlue
  • 486 Answers
SOURCE: where will i get a manual for a pro performance
30 or 35 degrees to sharpen cutter.
Posted on Nov 11, 2009
Testimonial: "thanks guru chainsaw is know sharpened thank you very much did not exspect an answer so quickly many thanks"
agent91
  • 2100 Answers
SOURCE: what size file do i use for a Ryobi chainsaw model pcn4545
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Posted on Feb 25, 2010
dontbother10
  • 2220 Answers
SOURCE: Lost manual, need to know what size file to
Your OM, pages 15 and 16. Top of 16 says 5/32s round file.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 05, 2010
  • 122 Answers
SOURCE: looking for instructions for McCulloch
There is also a good video on youtube using the Granberg sharpener.
http://www.youtube.com/watch?v=mtspO6DE8O8
Posted on Feb 08, 2011
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch Chainsaw electrimatic EM250-14 how to sharpen chain with electric sharpener.
I am not a great beleiver in electric sharpeners, they get the cutters too hot, this case hardens them making them brittle and they lose there edge quickly, they can no longer be sharpened with a file as they are like glass, purchase a good roller guide sharpener from a Husqvarna dealer, they are simple to use and work well.
May 27, 2011 | McCulloch MCC1514 14Inch 15 HP Electric...
My chainsaw has started to cut on an angle could the bar be up for renewal
The most likly cause is that you have sharpened the cutters shorter on one side than the other, all the cutters must be the same lenght, if this has been going on for some time it will wear the guide bar rail on one side and make it even worse, remove the bar and dress the rails with a file, get both sides as level as you can, now re sharpen the chain to get all the cutters the same lenght, or fit a new chain
Jan 24, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chainsaw cuts at an angle.....Why
The most common reason for this is uneven sharpening of the chain. Closely examine the chain and look for one ise to be worn more than the other. Try sharpening the dull side If sharpening is not a possibility, install a new chain. If the new chain also cuts to one side than the bar needs to be repaced as the chain is not being held straight.
Keep us posted,
Dan
Dec 23, 2010 | McCulloch Garden
What angle and size file do i use to sharpen oem chain on EM300S
The answer to this question is dependant on who makes the chain. Each manufacturer is slightly different. Determine the chain supplier then access the information at their site.
Jan 24, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
I am looking for a manual for Timber Tuff chain saw sharpener model cs-bwm>How to 'true 'the cutting disc, and tips on how to use the sharpener.
Go to Gemplers.com, look up Timber Tuff electric chain saw sharpener, click on it, go to Online Documents tab and you can print off the manual!
Nov 01, 2009 | Electric Chainsaw Sharpener
Garden Logo
43 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
