Re: How energy-efficient is a 1999 Kenmore 59569990...
Check that model number again. It should be posted in the refrigerator section or the freezer section.To get the true capacity, open the compartment door and measure the depth, width, and height inside the compartment. Do this for both the fresh food compartment, and for the freezer. Multiply the dimensions together (D x W x H) in feet. The result will be cubic feet for that compartment. The sum of them both will be the total capacity for the unit.
About all I could find on this was that it is not an Energy Star device so its efficiency is probably not that high compared to todays standards. This is also a discontinued model.
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA.Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers.Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models.Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system.Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics.SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period.SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics.SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings.The higher efficiency your product, the lower your long-term energy costs will be.Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place.Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost.Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations.If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
Unfortunately the 795.71309.012 is not listed at the EPA Energy Star site any more. (It's no longer qualified due to changes in the energy efficiency requirements.)
Newer refrigerators are more energy efficient than a 10 year old unit.
Look for a unit with an "Energy Star" rating. However, this rating is achieved by adding insulation to the box and the doors. If you look at a new unit, you will see that the doors and sides are thicker than your older unit. This is good and bad. Good becasue it will use less energy. Bad due to the extra bulk and space the unit will take up. You may also lose some storage space inside the refrigerator.
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it
even makes any financial sense to get estimate to repair, or is 10
years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation. Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs, such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems in the owner's manual.
Should you pay for a repair or buy a new model? The answer depends mostly on the age of your refrigerator, how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers), paying for a repair makes sense. Note that refrigerators under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old, it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator. Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent of a refrigerator you replace is likely to end up in a landfill. Thank You, HUUUM Please remember to enter a rating before you sign off!
You said,you have a Kenmore gas dryer mod. 110.95087400 ser. ms0201135 it's a
smartheat quiet pak9. Is there anyway I could convert this from natural
gas to electric, is there a conversion kit available.
They do have conversion kits for gas to LP. But I believe that there is no gas to electric. You must find a gas line from some where in the home and run it to your location, or buy an electric dryer. Remember that if you can run a gas dryer it will save you 30% on your energy bill over electric and in time pay for the cost of running the gas line to it. I hope you are not in an electric only house!
How old is the dryer?? Waiting for your response! Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Here is a interesting report that I just read today
Repair or replace?
Hello red rum, Yes, have seen this where the oven's thermostat needed to be replaced!
Bless You Let me know how you are! Please remember to leave a rating before you sign off! Huuum
Here is an interesting article i just read . Repair or replace?
If your refrigerator is under warranty or less than four years old (three years for top-freezers), paying for a repair makes sense. Note that refrigerators under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers. When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old, it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993. When it pays to replace.
Thanks for giving me the opportunity to help! Please do not for get to give a rating before you sign off! Thank You, HUUUM
Did you try turning it off...And then unplugging it for 5 minutes? Or if you can not reach the plug, you can turn it off and then turn off the breaker for 5 minutes! This can reset the system completely like we sometimes must do to our computer when they get unruly! How old is the fridge?
If the range is 6 years old or more it may not be worth spending to much money on it. Bless you huuum
Here is an article I just read about this matter!
Repair or replace?
Hello dooz127, You have a coolant leak some where.
How old is your fridge?
huuum,happy to assist you!
Repair or replace?
