Question about American Standard Heating & Cooling
What is error code 126 reference addendum document no. 18-hd32d2-/69-2009 for my trance thermostat
2 Suggested Answers
SOURCE: I have an error code
I am experiencing the same error code on my American Standard AC and according to Public. #18-HD32D2-8, error code 126 is in the Equipment Change Alert Group and the description says "Equipment does not match value stored at startup." Then, in a footnote, it says "A device has changed since Auto Discovery (See Installer Guide *S& 0706 to reset)."
This is all Greek to me so I'm calling my AC guy. I can tell you this, however. I bought an American Standard AC brand new just two years ago and one year ago exactly, it blew up. American Standard replaced it. Now, one year later, more problems.
I question the quality of American Standard and would not be inclined to buy this brand again.
Posted on Jul 24, 2011
My Trane AC thermostat (900 TOuchsreen) has an error code 126
Error code126 is equipment does not match value at startup. Usually a power surge or brown out can cause this problem. Turn power off to inside and outside unit, wait 5 minutes. Retry system.
Jul 15, 2016 | Heating & Cooling
Spa builder spa error code 126
Those are not Common Error Codes, Is it possible that the codes are characters other than the numerals you posted 125/126?
Jul 17, 2013 | Spa Builders Pool & Spa
I have an error code on my american standard model # ACONT900AC43UA communicating,programmable comfort control. Says to find the Error codes from American Standard Pub 18-HD32D2-8 but I don't have...
Jul 22, 2011 | Heating & Cooling
Which is greater,18 groups of 7 or 20 groups of 6
18 groups of 7 is 18*7 = 126
20 groups of 6 is 20*6 = 120
so 18 groups of 7 is greater.
Sep 14, 2010 | Vivendi Excel@ Mathematics Study Skills...
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Error 88 typedrive not connected
Tapeware error 88 refers to a tape drive not being found. Make sure you have disabled removable storage in services. What tapes are you using?
you can find your tapeware error codes by going, Start/Programs/Tapeware/Tapeware Documentation/printable documents/Tapeware error code reference
May 22, 2010 | HP StorageWorks DAT 72 Tape Drive
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Jun 22, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Error code 126 which is wxfw.dll. file try to uninstall desktop can't find thur tech.support was given web address when type in says changed or not available
Error Code 126 is a critical Windows error and is caused by a corrupt registry entry that should be repaired immediately to prevent further corruption in other applications and/or hardware. Risks include hardware failure, blue screen errors and fatal crashes.  I would reinstall windows if you don't have a backup registry disk. I would also look at my last download or new hardware install at the likly problem that coused the code.
Dec 14, 2008 | Computers & Internet
Heating & Cooling Logo
288 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
